Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Picture going green - Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
  • 4 more comments
  • Tx_Gator Apr 01, 2008
    E44W46LCD is the model number. There is flourescent green anywhere there is a shadow, and also when you change from Video 1 to Video 2, Side Video, etc and there is no input, the screen is also green. Normally it is black.
    Sorry, I posted a solution.....obviously not the solution
  • ewn813 May 03, 2008
    Recently purchased a used Zenith E44W46LCD. TV was being displayed outdoors and it was connected to a DVD. The movie played perfectly, no defects noted at all.
    5-10min after we connected it at home, it began displaying purple-ish colors where white and then turned all green. If i turn the tv off for 5 min and turn it back on, tv is back to normal, but then it starts acting up again. HELP!!!!
  • sojourn Jun 18, 2008
    Our picture is also green in the shadows. We already replaced the bulb about a year ago. Some pictures have a significant portion of green, others have little green. We are hoping this isn't going to be another large cost.
  • kurtvp Sep 15, 2008
    E44W46LCD picture is all green ???
    Help Please, Thanks
  • cherry_1950 Oct 05, 2008
    all pictures have a green tinge, although i have changed tint to red, itz driving me nuts, is it a new lamp needed,i still have a warrant on my tv
  • hershada123 Jan 05, 2009
    TV PICTURE START HAVING SOME GREEN IN THERE WHAT CAN I DO
I have just had the same problem connecting my dvd player and a digibox with my TV. All of the components work individually and the digibox and dvd player worked with another TV. Couldn't find any setting changes that worked on any of the machines. In the end changing the scart lead from the digibox to the tv sorted out the problem.
Posted on Sep 12, 2008
We have the polaroid flm 3201 and the shadows are all a toxic green looking color. What can we do to troubleshoot or fix it? Thank you,
Posted on Jul 05, 2008
Posted on Apr 01, 2008
  • Zenith Master
  • 8,617 Answers
Need to know the model number. There are many things that can cause your tv to go green. such as the green tube developing a short, or the blue tube being congealed so green becomes dominate. Post the model and I may be able to help you nail it down.
Posted on Mar 31, 2008
Dvd is connected and picture is black and white
red, green and blue should go to Component not composite.
Mar 13, 2012 | Coby LEDTV1926 19 in. TV
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
My 32" sanyo picture goes green
needs resoldering, in the heated areas, such as, crt socket board, power area, and high voltage area....it will be back to normal...
Oct 20, 2009 | Sanyo DS32920 32" TV
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Only red tube shows picture, but green & blue are on, just no pic
More likely the problem is the blue and green fluid in the tubes is so cloudy that its distorting the image. Get a fluid kit from www.tvrepairkits.com
Jul 29, 2009 | Philips Magnavox 9P6034C 60" Rear...
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pictures are coming out green
It seems like the previous owner messed with the color effect feature on this phone. After you take the picture and its under your picture file, you can edit it. view the picture and go to options. scroll down to image editor and clikc okay. click on tools (right hand side). scroll down to color effects and click okay. now you have a menu where you can change the coloring of the picture. You may want to try the enhance green feature first and make sure its not set completely to the +5. The default settings have red, green and blue all set at zero. Hope this helps!!
KC
Oct 26, 2008 | LG Shine KE970 Cellular Phone
GREEN TINT
Your green CRT may be going bad, You can get a replacement CRT ( picture Tube) at the following link very cheaply with free instalation instructions.
http://servicemanuals.vstore.ca/
Aug 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Factory Settings for Picture
Reset by powering off and unplugging from the wall outlet. If green problem persists than your Green CRT tube could be bad and in need of repair - they go out all of a sudden.
Mar 23, 2008 | Insignia IS 20" TV040919 TV
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
399 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
