Question about John Deere Tractor 1020, 1520, 1530, ITJD37
F935 re-aliwning drive shaft for deck after blade change?
I just changed the blades on a John Deere F935 mower. I am having a time trying to re-aline the drive shaft. Any tips or standard operating procedures. mMybe I'm missing th obvious?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
If you look close at the splines of the shaft you would see 2 of the splines are pinched together at the end of shaft and on the recieving end of shaft you would see that there is a small cutout where the 2 "pinched" splines would line up when slid together.
Posted on May 22, 2010
How to change cutting blades on john deere Z710A mower?
you should be able to life the deck to its highest possible setting, and get a wrench to remove the blades, you'll need 27" blades. the shaft may have a star pattern as well as the blades. when you replace them, you want to make sure you remember what direction the blades were sitting when you removed them and put them back in the same way, so you dont have blade interference
Jul 17, 2014 | John Deere Garden
The left blade on my John Deere LT155 stopped working
Besides the drive belt, there is a timing belt inside the mowing deck. The left blade is run by the timing belt. I imagine the timing belt is broken.
Apr 27, 2012 | John Deere Garden
Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Jun 16, 2011 | John Deere Garden
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
I HAVE A JOHN DEERE RIDING MOWER AND I AM TRYING TO CHANGE THE MOWER BLADES, THE BLADES WILL NOT LOCK SO I CAN TURN THE NUT THAT IS HOLDING THEM ON. SO HOW DO I LOCK THE BLADES SO THEY WILL NOT TURN?
you need to remove mower deck....and with correct size wrench hit it wrench with copper hammer to shock it loose....then do the same when tightning them up
Aug 11, 2010 | John Deere Garden
Mower blades froze up
Have you greased the bearings on the mower deck recently? Is there something jamming the blades?
Remove the deck and see if you can move the blades by hand. If you insist on not removing the deck to do this ... make sure the belt that drives the deck is not on the drive shaft of the motor to prevent accidental starting of the motor and instant mangling of your hand. If you can move all the blades, look for a faulty or worn out pulley on the deck. If the blades are frozen in their bearings, get replacement towers at your John Deere dealer or from a FixYa.com advertiser. If one is faulty or rusted ... replace them all ... as they are probably at or near the same condition. Do this job one time and do it correctly.
Thanks for your support.
Thanks for your interest in FixYa.com
Please evaluate this response.
Thanks
Good luck with your repair.
Jul 05, 2010 | John Deere 24HP VTwin Hydrostatic 48"...
John Deere Tractor 1020, 1520, 1530, ITJD37 Logo
539 people viewed this question
Top John Deere Toys Experts
Jim Goldsmith
Jim Goldsmith
john h
Charles T Nevin
Charles T Nevin
Are you a John Deere Toy Expert? Answer questions, earn points and help others
