The standby light flashes 10 times and then pauses for a few seconds and repeats. Also, where to get another remote as our local retailers haven't managed to get one for 8 months now!
Remotes can be ordered from various websites, I would check ebay, sony, those type of websites. The standby light flashing means your bulb on the TV needs to be replaced. Good luck.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem. Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Flashing standby light is an error code that is specific, there would be pause of 3 seconds in flashing, so count pause to pause and let me know that how many times red standby light is blinking to diagnose problem.
Thanks.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
The POWER/STANDBY (red) indicator flashes three times If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing) A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing) A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
tv takes a few goes to turn on and red light is flashing 10 times
