Question about Char-Broil Big Easy 463823304 (LP) All-in-One Grill / Smoker
Burners not heating well
I have a Charbroil Big Easy which has been sitting for several years unused. It has gas, but the burners only turn on about halfway. Do you have some ideas about how to clear the problem? Do you also know where I can get an owner's manual?
Thanks, Gene
  • Char-Broil Master
  • 2,598 Answers
Take the burner out and soak it in clr then rinse, then dry and put it back in check gas injector is not blocked ,just give it a good clean ,manual try google
Posted on May 16, 2010
I had my charbroil grill for 2 yrs and I now when I turn on the propane tank and ignite, I hear hissing followed by it lighting then flames proceed to come out the front middle burners. Do I need a new...
Before buying anything, look into the burners for spider webs. The webs block gas from getting to the burner and will fire back. This is dangerous. Look carefully where the gas nozzle enters the burner tube.
Gary
Sep 04, 2011 | Char-Broil CharBroil Master Flame Gas...
While grilling we had a flare up that quickly turned into thick black smoke rolling from our gas grill. we shut off the grill and got the flames out. what could have caused this? is it safe to try and...
If you have a grill that is several years old, some of your burners may be rusted and deteriorating, causing these large, out-of-control flames. It's definitely not safe to us in this condition. Remove the cooking grids and all parts above the burners and examine each burner with a flash light. It's also possible the seams have split which may be harder to tell that it's defective. If you can remove each individual burner to inspect it, do it and and make sure there are no restrictions inside the burner, like bug nests, debris, etc that could clog it and force gas out the venturi tube at the orifice. If you had moved or transported the grill recently before using it this last time, it may have jostled something loose or caused the rusted burners to fall apart so quickly. Hope this helps. Let me know if you need more assistance. Douglas
Jun 08, 2010 | Char-Broil CharBroil Master Flame Gas...
Very low flame, like very little gas is getting thru, tank is ful
Okay, what you are dealing with is called "vapor-lock". The way these grills need to be turned off is, close the tank valve first and after the burners go out, then turn the burners off. The way you are doing it is trapping the gas and you are getting a weak flame. Fortunately this is an easy fix. First, light the grill by turning the gas valve open, then turn the burners on to light the grill...as soon as that is done, close the gas valve on the tank then turn the burners off. Repeat this procedure until you get a good flame. If this procedure hasn't fixed the problem after the third time, you need a new regulator and regulators are easy to find in any home improvement store like Lowe's or Home Depot.
Dec 15, 2009 | Weber Genesis Silver B Grill
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
Replacement of gas burners
Hello, The model number that you gave is relatively simple to change the burners.
  1. Remove the 3 cooking grids
  2. Remove the 3 vaporizer tents
  3. Between each burner is a "pal nut" that just pushes on and will likely be destroyed when you remove it. They run a couple bucks each at Sears, part # 7000132
  4. This will release the carry over tube holding the burners down and the burners can be lifted out.
  5. Ensure that you clean out the carry over tube when you reassemble. This carries the flame from the first burner across to each of the rest of the burners when lighting them.
  6. Reassemble in the reverse order ensuring that you put the burner tubes over the burner valve tubes when reassembling.
You can find a parts listing with the parts numbers at: http://www.charbroil.com/Parts/80/Performance-Series.aspx
If this was helpful, please vote yes. Thank You!!
May 29, 2009 | Char-Broil Advantage 463453306
Only one of four burners will light.
Hello, there is a carry over tube between the burners that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000280. They can be purchased directly from Char-Broil or Sears parts.
http://www.searspartsdirect.com
If you find this helpful please vote yes. Thank You!!
Apr 19, 2009 | Char-Broil Advantage 463453306
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
I have a char-broil 3 burner grill that is about 6 years old. It has 3 circular burners. The amount of gas now getting to the burners is equivalent to low even when the dials are on high. Do I have a...
most likely burner problem try removing burners (they generally just lift out or held by 1 or 2 screws) clean the sides of the burners with wire brush most likely then orifices on burners are clogged hope that works for you
Aug 23, 2008 | Char-Broil CharBroil 4637318 Grill
Char-Broil Big Easy 463823304 (LP) All-in-One Grill / Smoker Logo
111 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
