Question about Whirlpool ED2FHEXN Side by Side Refrigerator
How do I know which icemaker replacement to order for this model?
  • 283 Answers
Use p/n 4317943
Posted on May 16, 2010
Icemaker 106 626133 in 1987 Whirlpool ED22MMXRW sid-by-side
Happy to report that I now have a working icemaker. I had to replace the control module--just replacing the gear was not sufficient. The wiring was slightly different for the new module because it had a side connector instead of one coming out of the lower left corner, but I was able to use front metal plate plus its attachments (motors and switches) of the new to replace the similar parts on the old.
Jul 16, 2012 | Whirlpool Refrigerators
PART THAT SUPPORTS THE ICEMAKER BROKE OFF AND I NEED A REPLACEMENT. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
ICEMAKER BROKE AND I NEED A NEW ICE MAKER. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
Jul 07, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My samsung model #RS2578BB AUTOMATIC ICE MAKER IS NOT MAKING ICE PLS ADVISE
TOOLS NEEDED:
Eyes (fair to good shape)
#2 phillips screw driver
Flashlight
Lets assume it was working at one time right? And the FREEZER temp is BELOW 20degs
REMOVE storage bin to see icemaker.
LOCATE test button on underside or rightside of clear motor asembly.
(should be black)
Press until icemaker starts, then release button. Watch the tray twist and return to upright the should fill with water.
If icemaker worked: ICE SENSOR MAYBE BAD> ORDER NEW ICEMAKER IF THE ICE DOES NOT EJECT AFTER 4
If icemaker did not Start by pressing the test button.: UNPLUG the frig or go the Main Service Panel to the house (BREAKER BOX) and shut off the power and verify NO LIGHTS INSIDE THE FRIG>
Remove the concealed screws holding the icemaker to the ceiling.
PULL the icemaker forward to release icemaker. Using the Flashlight
LOCATE the wiring harness on the ceiling. Look for the RELEASE and Squeeze and pull down. Inspect the electrical pins to make sure all pins are equal and secured. If all is well there?
THE PROBLEM COULD BE either: ICEMAKER or Main PC Board
I would order a Icemaker assembly first since it is the least expensive.
1-800-Samsung
Good Luck and Cheers!
Seen It B4
Your Welcome
Jan 02, 2010 | Samsung RS2578BB Side by Side Refrigerator
Front gear frozenin u line marine icemaker
Then you need to replace the faceplate. You need to visit www.u-line.com and under customer service you will see parts locator to order the part. Make sure you have a model number
Aug 05, 2009 | U-Line Icemaker
How to replace alumalastic in u-line icemaker
Hi
Not all U-lines have alumalastic under their icemaker. What model do you have? Alumalastic will come with the icemaker with directions on how to put it on. It's a caulking material that is spread under the icemaker to cover the heater and sensor tube. If you remove your icemaker you should see it if it needs it.
Jul 29, 2009 | U-Line Icemaker
Water from ice makers leaks and builds up in botom of freezer
ice maker leaks are usually a sign of icemaker mold corrosion eating the lining off the icemaker causing it to leak. the only repair is to replace the complete icemaker. you will need a complete model number from the unit and the part can be ordered online thru whirlpool or some of the other appliance parts sites. you may even have a local parts warehouse where you live. hopw that helps peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Part not available
Thanks for getting back.
I've searched your model, and found both the main icemaker gear and a complete replacement icemaker unit as a drop-in replacement.
Gear is listed at $5.25 , and complete unit at $ 81.41.
It is usually the fingers or the gear teeth that break.
Try this page for ordering information - Both are held in stock
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=114043
If I've identified the wrong part - please get back to me If I can help further
Thanks for using Fixya.
Jan 01, 2009 | Kenmore 57029 Side by Side Refrigerator
Water drips from underneath icemaker and freezes in bucket
If you find the offending part of the ice maker, I've had good luck with these guys when ordering spare parts. Here is a link for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133512
Jan 01, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
73 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
