Question about Acer AL1916W 19" LCD Monitor
Remove stand I want to take the monitor as part of a mobile office. I found a case everything will fit in, but with the stand on the monitor is too big
  • 11,361 Answers
PadPal 7 tablet stand/ holder wanted
You will find many iPad Holders Accessories with various style and size at complement. They provide wide range of office accessories like laptop stand, monitor stand and many more.
Jan 30, 2014 | TrendyDigital Padpal tm Convertible...
Tip
Removing stand arm
Hi all
Thought I'd share this.Lenovo discontinued the excellent L1940P, which had a stand that allowed pivoting as well as tilting and height adjustment.
So I've bought a L1951P and mounted it onto a stand from Ergotron.
Problem: the Lenovo comes with a hinged arm extending below the bottom of the screen. The Lenovo-supplied stand fits on the end of this arm. How to remove this arm so that it doesn't get in the way of a VESA mounting?
Well, I called Lenovo tech support, and they know nothing beyond what's in the manual that I've read. They claim that this arm is an integral part of the case and can't be removed. Wrong. I really love it when the people I talk to in tech support are actually people who know more about their product than I do...
At the top of the arm is a cylindrical plastic cowling covering the arm hinge. Put the monitor down flat on its front (on a cloth is a good idea to prevent scratches), tilt the arm upwards away from the case, and use a pen-light to look into the gap under the arm. You'll see a little tab on each side, inside, which is part of the cowling and locks the cowling onto the main case.
Use a small flat-head screwdriver to gently push this tab outwards - if you can apply a little pressure away from the case (i.e. upwards, as the case is downwards at this point) as well, you'll see the cylindrical cowling come away from the case on that side. Repeat on the other side. Remove the cowling, and you can access the 3 bolts that hold the arm onto the case. Done!
on Nov 02, 2010 | Lenovo ThinkVision L1951p LCD display ...
Desktop to monitor
You may have to check BIOS for an on board video and disable. Or, enable add-on card.
Nov 22, 2012 | Dell OptiPlex 210L PC Desktop
I'm attempting to repack my AL2216W LCD Monitor into the original box. When I slide the two foam protectors on the ends, it won't fit into the box. The stand is in the way no matter how I position the foam...
Of course there is a trick to this. Remove the stand by pushing gently on the clip at the bottom. I usually turn it upside down to do this. Then lay the stand on top side of the foam.
Please rate this answer as the only thing I get for answers is a rating.
Apr 11, 2010 | Acer AL2216W LCD Monitor
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
Feb 23, 2010 | Acer AL2423W LCD Monitor
Remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
Jan 05, 2010 | HP w19 19" LCD Monitor
How do I open it to look inside?
First, lay the tv/monitor on its screen on something level and soft as not to damage the screen. Remove any visible screws that seem to attach the base to the unit. Some models you have to look under the base for pins orso to push together to slide the base from the stand, only then you could reach the 1 screw holding the monitor to the stand....Once stand removed, remove any screws you see holding the monitor casing together, usually only a few screws since they are mostly held together by plastic "clips"...Once screws are removed, then gently insert a flat(screwdriver orso) inbetween the case?housing, repeat this all the way around the case/housing till completely loose....You will prob have a few wires or maybe a ground wire that you would have to remove before completely being able to seperate both sides(front case, back case)..Sometimes you might have to unscrew and remove the skinny washer/nut around the cable input orso..
Nov 18, 2009 | X2Gen MG19MY 19" LCD Monitor
HP 1740 popup of OSD Lockout
Dont take apart the monitor!?!?! Hold the Menu button for about 15 seconds, the manual said 10 but i found by holding menu for 15 seconds it removes the OSD lockout.
Dec 11, 2008 | Computers & Internet
How to dismount the monitor
What stand do you have? If it is screwed to the back with 4 or 3 screws, they must be removed first. look along the bottom edge and you will see 3 slots where the two outer cases match up. Put a flat screwdriver into the opening and twist, follow all the way around until you can remove the back half. Cut the tape holding the flat wire and remove the front half to remove the printed board under the front cover. You should now be inside the case. Remove the screws to remove the steal cover to find the printed boards under it. Reinstall is the reverse.
Sep 13, 2007 | LG Flatron L1715S 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
141 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
