Question about Garmin nuvi 205W GPS Receiver
Suction cup mount keeps falling off windshield . Works for about 1 - 3 days and then just lets go.
  • 32 Answers
The suction cups ****, don't they? ;-)
The problem is that temperature variations (bright sun vs. cloudy day) causes pressure changes inside the vacuum seal, and it eventually fails.
You can try spraying the cup with water before attaching it...the water helps the cup keep a better seal. Vaseline works even better.
Ultimately, I ended up buying a universal mount that fits right onto one the dash ventilation louvers...no problems since.
Posted on May 16, 2010
My garmin nuvi 350 suction mount falls from the windshield after several days.
I believe they all do that, I own a Garmin and I bought what looks like a bean bag because I got tired of my suction cup mount falling off my windshield. The nice thing about the bean bag mount is that you can move it closer to you and place it anywhere on your dash. I bought mine on ebay from the Mount Guys they have a big selection of mounts for all types of GPS's take a look you might want to make the change too.
I hope this helps you out and if it did please leave me some feedback
Apr 03, 2011 | Garmin GPS
Mounting of gps can't mount on windsheild.
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Jan 04, 2011 | Tomtom ONE XL GPS
WIll not adhere to the windshield... suction cup does not hold GPS
Dec 31, 2010 | Tomtom GPS
How exactly do i fix the suction back onto the windscreen please? I have just bought a tomtom and don't understand the drawings!
Dec 31, 2010 | Tomtom ONE GPS Receiver
I have purchased three of these products from this company. I am sick and tired of this navigation system falling out of the window while I am driving. I am a salesman that purchased this product in good...
Brian - you should contact Garmin directly at www.garmin.com - this site is not affiliated with Garmin in any way. I'd suggest that you secure the GPS to the center of the windshield or use the semi-permanent dash mount instead of suction cup mounting to the windshield near the driver window.
Jun 30, 2010 | Garmin Nuvi 760 Car GPS Receiver
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
Sticking my nuvi 260W to windshield - after a few days often in sun [winter/spring Mass.] thesuction cup mount falls of to dashboard- risking damage to nuvi. advice? without having to use permanent...
Here is what I do. I clean the spot on the windshield very good with Windex or another good window cleaner. I also clean the suction cup surface while I am doing the windshield. Next I place the GPS next to the Rearview Mirror. and connect the suction cup. Then I take the power cord and use it to tie a knot around the suction cup mount and then I loop it around the Rearview mirrow twice leaving no slack between the GPS and the Mirror. Be sure to not block you view in the mirror. If the GPS come loose from the windshield it will just fall far enough for the power cable to catch it and will just be swiing there instead of falling to the dashboard or floor. This is kind of a Mickey Mouse way to do things but it works.
Apr 08, 2009 | Garmin nuvi 250W GPS Receiver
LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Dec 07, 2008 | LG LN740 GPS
Suction cup problem
Make sure your windshield and the bottom of the suction cup is clean. Clean it with some warter & detergent and wipe dry. Try wetting the bottom of the suction cup before applying it to the window.
I recommend not using the window mount. I recommend using the dash friction mount. You take the risk of cracking your LCD screen when it falls.
1. The dash friction mount will not fall.
2. It's easily removable/
3. It's legal in all 50 states (window mount is not).
- Jim
Nov 05, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Suction Cup (Rubber)
Put a drop of dishwashing detergent and a few drops of water on the rubber and distribute it evenly before You mount it to the windshield. This mixture enhances the suction power and keeps the rubber soft. Repeat after 3-4 months! If You don't like the look of it on the outside of the window, put a smiley sticker on it! :-)
Aug 09, 2008 | Garmin Suction Cup Mount with 12V Adapter...
Garmin nuvi 205W GPS Receiver Logo
571 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
