Question about Teac GF-600 Turntable
Turntable belt is off.
The turntable belt came off my P-A688 TURNTABLE AND I DON'T KNOW HOW TO PUT IT BACK ON. I NEED YOUR HELP. CAN YOU HELP ME PLEASE?
    Guru:
  • 256 Answers
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
Posted on Jun 12, 2010
Need a diagram of the belt configuration
Check out YouTube there are some standard videos on belt replacement that might apply to your model.
Oct 14, 2015 | Teac P-A688 Turntable
Need a new belt
Measure the old belt, make certain you know how it fits before removing. You need the diameter and width in MM. You don't need to be spot on with these! Put the results with the words "Turntable belt XXmm by XXmm" into Google.
Aug 13, 2013 | Teac P-A688 Turntable
Turntable won,t run when pluged in the table is brand new
Sounds to me like the bellt has slipped off. To replace, lift the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Jan 06, 2011 | Teac P-A688 Turntable
Hi, the belt on our Teac Turntable has come off while moving to new home. Can I get manual that shows how to put it back on?
If you open the top lid of your turntable, you will see a black rubber disc that sits on the pladder, it should come off revealing the metal pladder, you should see holes that will show your belt and the turntable motor when pladder is rotated. In order to put the belt back on you must remove the pladder, but before you do check to see if there is a C clip holding it down, after removing the clip the pladder should come off, put the belt on the inner rim of the pladder, now slowly work the pladder on the spindle make sure one of the pladder holes allows you to see the motor, put a small blunt object between the belt and the inner pladder and use it to stretch the belt to slip over motor then push the pladder down and rotate it making sure the belt is turning with the motor, next replace the rubber disc and finally the C clip if it is present.
Dec 21, 2010 | Teac P-A688 Turntable
Need assistance putting belt on turn table
"Put the thing on the other thing. There you go."
- Everyone trying to explain this to me on the internet.
May 27, 2008 | Teac P-A688 Turntable
The belt on my turn table came lose
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. if it keep coming off they can help you size a new one.
May 10, 2008 | Teac P-A688 Turntable
01- Remove the rubber cushion.
02- Remove the Turntable Platter
03- Place your drive belt around the ridge inside the platter
(Make sure that it is not twisted)
04-Place your Turntable Platter back on the unit
05-rotate your platter until you can see a brass knob through one of the round holes in the turntable. (Your belt must be placed around the brass knob) The best way is to take a toothpick and carefully slide it under the drive belt and then pull it out enough that you can place it around the knob. I had the same problem and the above works. If you still have problems getting it back on contact me 352-377-1828......
May 03, 2008 | Teac P-A688 Turntable
Too slow?
this can be caused be a new belt being too wide, you may need a narrower belt.
Dec 22, 2007 | Teac P-A688 Turntable
Teac turntable belt came off.. help!
Through the 2 holes on the platter, lift the platter up. Take the belt, flip the platter over, and stretch it around the center ring. Flip the platter back over and turn to so one of the holes is over the spinning motor. With your finger or with a blackstick, stretch it back onto the motor head.
Also check the belt for wear....that should do it.
Keep me posted.
Dec 05, 2007 | Teac P-A688 Turntable
Belt came off!
If the belt is plus minus 6 millimeters wide it fit on the largeflywheel on the outsie and then on to the pulley of the electric motor Do not strech it too much
Oct 03, 2007 | Teac P-A688 Turntable
Teac GF-600 Turntable Logo
162 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
