Question about HP Pavilion dv6000z Notebook
Im using vista as my os. and my laptop is hp pavilion, both my control keys are not working. what should i do?
  • HP Master
  • 2,404 Answers
Try a USB keyboard on the laptop just so you can bypass the laptops keyboard. If the USB keyboard works properly then you know that your laptops keyboard keys are bad and you would need to replace the keyboard. If the control keys don't work on the USB keyboard then you know that its a setting in windows thats causing the keyboard to act up.
Posted on May 16, 2010
    Novelist:
  • 83 Answers
You might have changed settings of stickey keys
Check the setting in start- control panel- ease of access center- make keyboard easier to use.
Go to sticky keys -uncheck the box.
Also check the other settings in it.
It will resolve your issue.
If yes.. if not..you might need to remove the keyboard driver from device manager.
regards,
Dreamkam
2 Suggested Answers
  • 280 Answers
SOURCE: hp laptop,,vista os,,turboc not working in full screen
As for the sad part, Vista does not support fullscreen for DOS applications. You can use DosBox emulator to emulate TC and expand it to fullscreen. But be warned that it might crash at times when your program exceeds the limits of DosBox. I've tried it for the same purpose as of yours. Be sure to check your complete presentation before the final day.
Posted on Jul 28, 2009
Why isn't it working after i have tried the product key 8 times?
product key rubbed off bottom of hp compaq 6730b - serial ...
h30434.www3.hp.com > Laptop & Notebook > Notebook OSJul 22, 2011 - 2 posts Hi I have asked Microsoft on how to get my key from a rubbed off lable on the bottom of laptop I mean, why put it there, its going on my "LAP&.
Vista Activation - Product Key Invalid - HP Support Forum ...
h30434.www3.hp.com > ... > Desktop OS
10 posts Windows Vista Product Key not valid. Vista was preinstalled on the Pavilion desktop I bought 2 years ago. Suddenly there is a problem and I need to ... - 496013.
Sep 30, 2015 | Compaq Presario 700 470024-192 Notebook
Hp pavilion dv9843cl. On normal startup the screen starts normal when you see the progress bar. When the desktop screen should load I get vertical lines of numerous colors and have to hold down the power...
a notebook running VIsta, i guess.
Answer 1: the OS is corrupted. (what ever it is) VISTA?
or GPU dead.
never post PC questions lacking what OS is loaded. please.
why do you say desktop?
does that mean the internal screen is dead, long ago and now you run external screen?
DV9843C
if the system is still as HP made it, IS IT?
the F11 key will pop up a screen called HP restore for VISTA
use that to reInstall the HP operation system with all HP , drivers
The HP will go back to DAY 1 condition. doing that.
if someone, put in a new HDD, and the then used Microsoft disks
to install an MS OS, then the F11 HP features will be dead.
or if the Hard disk was ever fully erased. same. deal.
we cant know what you have.
im trying hard to carbon date this hold Notebook.
year made.
as you may not know the EPA mandated lead free,
this laptops that year, all failed for, GPU chip solder joints failers
called Solder ball horrors.
in the year 2008.
HP no longer supports this laptop.
they have a spec page only, software.
here is the dead HP list
of there Pavillion page.
https://support.hp.com/us-en/retired-products
how over the list is wrong, (common)
the list in this case means soon, gone , support'
this notebook had VISTA new.
(old)
first one vista 32 was 2008
so is a solderball, laptop, the one year never to buy any laptop.
the GPU can fail, and most did.
and the screen goes dead, then the external too can go dead.
external VGA.
hope that helps.
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv9800-entertainment-notebook-pc-series/3675209/model/3689916
May 04, 2017 | HP Hewlett Packard DV9843CL Pavilion...
HP Pavilion dv5-1125nr entertainment PC Notebook
no OS stated, is this XP?
my guess you are using the HP backup or ?some HP software to do that, you never said.
the day to do that is day1, not 10 years later
you will end of with a useless disk in any case.
back new in 2008, long ago, the Laptop has this card inside,
instructions saying to make a recover disk, now,
that will work then, but now, 9 years later.?
how can it?
if XP its a corrupted OS and now is not supported.
same now with VISTA.
your PC came new with Vista or 7 (both 32 bit or 64)
what is there NOW.
the building a recovery disk needs all things perfect.
1: OS not corrupted,
2: recovery partition not corrupted or missing
3: DVD drives still good, and correct media used.
4: Driver for the DVD must be correct. from HP.
5: HDD must be bad, and passes the S.M.A.R.T tests.
one trick to get there is push the F11 key.
that is the HP recovery magic key (power on hammer f11,,, bam)
then recovery the OS then make the recovery disk.
now that the OS is ok , the DVD-r (or what it needs) will work.
if the F11 key fails, that means the HDD is bad or the recovery partition is corrupted, as most are this old.. 9 long years later.
Oct 29, 2017 | HP Pavilion dv5-1125nr Notebook
Hp laptop,,vista os,,turboc not working in full screen
In order to get the full screen use the key combination of Alt and Enter
If you right click on program, in properties,you'll see an option called program compatibility. Make compatible with earlier versions
Jul 28, 2009 | HP Compaq 2510p Notebook PC
Vertical scroll not working on touchpad
The easiest way is to borrow a mouse and allow it to be discovered. This will give you the device tab in control panel. It should then work with your mouse.
Jul 23, 2009 | HP Pavilion dv4000 Notebook
I need driver hp pavilion dv1000
Hp has not posted a driver for Vista for the laptop. The XP driver is available at
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=435618
Install the driver and check if it works. Comment if it doesn't
Jun 24, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000 OS(s)
The product key on the label on the bottom of the laptop will only work for the version of Windows that was installed on that laptop.
You can purchase an upgrade Windows Vista Ultimate and to use in conjunction with the existing Vista Home Premium.
Mar 30, 2009 | HP Computers & Internet
Top letter keys on keyboard not typing
I think its likely to be a hardware problem but check that your keyboard settings are correct for your country. Look in the control panel and then Keyboard settings.
Does the tab key work?
Jan 21, 2009 | HP Pavilion dv6000z Notebook
Audio and vedio drivers
Go start run then type DXDIAG and let me know for system models and i will find right driver for you!
Jan 06, 2008 | HP Pavilion dv9000z Notebook
Windows operating system
you can make a dual book (multi OS) on your laptop so that you can just switch over to XP or vista and vice versa.
try this article on MS on how to install a multi OS. i haven't tested it in vista though...but i think it would work..please let me know.
also..you can use a Virtual PC and install XP there, its much more easier.
Oct 30, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
