Question about Coleman Garden
I have a factory reconditioned Coleman Powermate 2400 PSI-2.0GPM and am getting no pressure at all! Help!
    President:
  • 2,030 Answers
Bad pump..take it back where ya bought it or call coleman for service
Posted on May 16, 2010
Need the manual
A model number would have been helpful; however this may be your manual:
http://www.powermate.com/pdfs/2007/11/10/manual_pw0501400.pdf
If the above is not your manual, check your unit for a model number and then review or search the list here:
http://www.powermate.com/productmanuals.php?cat_id=6
Jun 28, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
I have the Coleman powermate 2400 PSI pressure washer and on initial start it sprays and has great pressure. But once I release the spray handle it will not spray again, not even one drop of water. I have...
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
Oct 22, 2009 | Coleman Garden
Coleman powermate wont restart spraying after release trigger
Make sure your fluid level in the pump is changed and at the right level.
Sep 24, 2009 | Coleman Garden
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
The pressure reads 40 psi on both guages on this
with it running check regulator knob .it pulls up turn right pressure should go up.if not regulator bad
Jun 20, 2009 | Coleman Powermate 11 Gallon Air Compressor
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman Pressure Washer Problem
your pressure relief valve is stuck open. i know that may sound too simple but it depends on if you use a cleaner with the water when your using it , not flushing with clean water after use can cause the housing of the aluminum housing of the relief valve to corrode. the valve can't move back and forth as it should because the o ring won't slide.
Jun 20, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
181 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Coleman Garden Expert? Answer questions, earn points and help others
