Question about Microwave Ovens
The microvave does not heat anything up. The light works, turntable works, the 'oven' goes 'on', but neither the food nor the liquid heats up. It was working one day and then not, the next!
  • 276 Answers
At minimum, it'll be a High Voltage fuse blown. There could have been a power surge, or it could be an indicator of something more wrong with the microwave. Not that expensive to fix.
At maximum, it'll be the magnetron (the component that creates the microwaves). This could be an expensive job.
Refer to your manual or to the manufacturers website for information about repair locations.
Posted on May 17, 2010
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
Clock,lights and turntable work but does not heat
Open the microvave discharge the capcitors.If you don't know then stop here and call pro .
Open it First check physically the nothing is burnt.I everything seems okay then, check the resistance of the magnetron and also the fuse.PLEASE DON'T TRY IF YOU DON'T KNOW HOW TO DISCHAGRE THE CAPACITORS.
Thanks
Please rate my work
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Food is not heating, can u help me?
If the only problem is that the food does not heat up, but the rest of the oven works, like the light, turntable, display and keypad, then the problem is with the magnetron circuit. It the circuit that generates the microwaves that heat the food. It can be expensive to fix since the replacement magnetron can cost as much as a new oven, so it rarely worth fixing. The symptom of a shorted magnetron is a loud buzzing sound when you try to run the oven.
Jun 03, 2011 | Sharp Microwave Ovens
It has power but is not heating anything
In order for a microwave oven to cook foods, its "engine" - the magnetron - must also be functioning. If the keypads, turntable, lights and all other functions are working but the food is not cooking, the magnetron has failed. Some local repair shops can provide a reasonable cost to replace, and it comes down to how old the oven is and is it worth repair or replacment.
Feb 15, 2010 | Microwave Ovens
Oven does not heat food.
either the h.v. diode,h.v. capacitor or the magnetron tube are suspect here due to the no heat condition you have
Oct 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
