Question about Precor C956i Treadmills with HR / WholeSale
Sounds like airplane taking off
On it today...set at 6.0...loud. stopped suddendly, then started back up again. the tread looks like it is off .5" from where it was running (by the marks in the metal bar) and i pulled it back in place, but quickly went off track again.
  • John Mazmanian
    John Mazmanian May 16, 2010
    How long have you had this treadmill and have you or a service company done any maintenance on the unit.
  • jpcl May 16, 2010
    6 years. precor M9.27. No maintenance at all.
    President:
  • Precor Master
  • 832 Answers
1. You may have a worn belt and deck problem ( #1 problem on treadmills ). Test by the following procedure:
a) without the power on stand on the walking belt
b) push the beltsounds like airplane taking off - 2_bing.gif in the direction it normally turns
c) if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction.
You must physically inspect the belt and deck. The deck should be smooth. The belt should have aconsistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. If their is no signs of excessive wear then the next step is to lubricate the deck follow this procedure:
Before applying lubricant, the belt must have the tension reduced and cleaned deck. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition.
Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. Lift the belt and slide a moist towel between belt and deck, slide the towel the length of the unit to catch the contaminants do this a number of times inspect towel and need be use a fresh towel and repeat cleaning let dry then apply the lube in the center upper third of deck then start unit and walk on it @ 1-2mph for about 5 min. You may purchase the lube from National Gym Supply @ gympart.com Part# TM001 or call them @ 1-800-496-7278 their on the west coast. At this point I believe your problem should be resolved if the above procedures have taken care of problem take a look at the next step, as mentioned the #1 cause of treadmill failure is lack of maintenance of the belt a
Posted on May 16, 2010
A loud airplane like sound is coming from the ice maker area. it goes away and comes back later
Good Afternoon Friend,
I understand that you are hearing a loud airplane sound, intermittently coming from the ice maker, on your Frigidaire refrigerator, model# FRS3R5EMB. You will hear a buzzing sound as the water valve opens to fill the ice maker during each cycle. I suggest resetting your refrigerator, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try getting ice out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire FRS3R5EMB Side by Side...
An LS 6 error on a Bowflex treadmill - I put in a new speed sensor and recalibrated. The tread stops moving but everything else keeps working. I can turn it off for a minute and turn it back on, it will...
Sounds like the speed sensor may be intermittently losing the speed signal. You use a business card slipped between the pulley and the speed sensor to set the gap- push the sensor against the card, then remove the card. That should insure a good speed signal.
May 06, 2014 | Exercise & Fitness
2002 VW Cabrio GLX while driving car there was a loud bang and it automatically came to a sudden screeching stop as if the car was thrown into park
Can you start it and it runs fine but in park or nuetral? If so the issue is related to something on the drive axel. It could be a CV joint or bearing.
Feb 05, 2014 | Volkswagen Cars & Trucks
1990 Grand Am won't take fuel after loud "pop"
when you turn the switch on listen in the fuel tank to see if the fuel pump comes on
Jun 29, 2009 | 1990 Pontiac Grand Am
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
1999 cavalier battery light coming on but has new battery
start car ,unplug 1 of the batt. cable dont let cable touch anything if car stops doesnt look for alt. check all connections at alt. are good
Feb 25, 2009 | 1999 Chevrolet Cavalier
99 cavalier battery light comes on but new battery....
it sounds to me like it could be the alternator im afraid but the only real cheap way to tell is time. if you continue to drive this and keep a check on wether it still starts or lights dim, with it being a new battery it is going to take a while fot it to go flat. if it does then try not to drive it too much as this will break it and cost you even more.
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Focus/Screen block bad
This part is called the Focus Block and has 6 controls, 3 for focus and 3 for screen. The screen is the overall brightness of the CRT and the focus is the sharpness. The part can be ordered by description from any RCA parts distributor but the controls should be set by someone with experience.
Jun 26, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Precor C956i Treadmills with HR / WholeSale Logo
223 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
