Question about Xerox Phaser 7400/N Printer
Xerox phaser 7400 replaced yellow toner, but still getting replace toner error. I've reseated it twice, reseated the imagining unit and tried turning it off.
  • gourmetinvit May 16, 2010
    Thanks - I had actually already tried that too. Guess I'm calling service. :( Thanks!
This happened to us today --- really frustrating! We ended up changing the Yellow Imaging Unit early (it was 'close to end of life') and now the yellow toner is all happy & full again. . .
good luck to you!
Posted on Apr 12, 2012
Open and close cover after replace chip cartrige
Posted on May 19, 2010
    Scholar:
  • 92 Answers
You can try do a NVRAM reset. If after that you still have the error message then I would tell you to contact the Xerox team as you might have a wrong consumable (defected/wrong CRUM) information.
NVRAM reset: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000002092637520,K=9394,Sxi=5,Case=obj(3085)
Posted on May 16, 2010
  • Rui Oct 13, 2010
    I hope service manage to solve it for you.
    if you believe the tips provided were of any help please mark the thumbs as a vote:)
    thanks
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox Phaser 7400 U28 error message
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
May 20, 2012 | Xerox Phaser 7400/N Printer
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
Yellow band on page
It is probably the yellow Image Unit (the toner fits into it)
Dec 01, 2011 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400 giving error - replace imaging unit- what solution now?
Did it specify a color you should replace? The machine has 4 image units (CMYK) each with a different part#. Replacing them is easy, no tools required. Open the top door, lift out the entire image unit, move the toner over to the new unit, and lower the image unit. Here are the part #'s for the 7400 for each color. Iteminc.com has these online.
C - 108R00647
M - 108R00648
Y - 108R00649
K - 108R00650
Good luck, hope this helps. Thanks for using FixYa!
Aug 05, 2011 | Xerox Phaser 6350/YDT Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Phaser 7400
The closest I can find to your description is a U6-0 and the suggestion is to replace the transfer belt assembly,
Feb 11, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 7400/N Printer Logo
1,021 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
