Question about Karcher 2500 PSI Pressure Washer
I have pressure washer machine with honda Motor gc190 not start and gas is coming thru the muffler
4 Suggested Answers
  • 33 Answers
SOURCE: honda pressure washer 2700psi
your inlet up in the housing may be plugged.
Posted on Apr 21, 2009
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
Govoner arm came off how to put it on in the right place
thats a honda engine
Search Results
Honda Engines ' GC190 Owner's Manual
engines.honda.com/parts/ownersmanuals/gc190 Download or purchase Honda Engine owners' manuals for the GC190.
Honda Engines ' GC190 4-Stroke Engine ' Features, Specs, and ...
engines.honda.com/models/model-detail/gc190 Official specs and features for the Honda GC190 OHC engine. ... is a small four-stroke gas engine designed for premium residential use. ... Owners Manual.
[PDF]honda 6hp gc190 repair manual.pdf
www.publicwalls.org/honda/honda-6hp-gc190-repair-manual.pdf
Apr 08, 2016 | Horizontal Engine 6 Hp Ohc Gc190mha2
How do I remove the connectors from the output hose?
Does it have brass quick connects or is it screwed directly into the pump? Feel free to email me.
Sep 26, 2014 | Karcher G 3050 OH 3000-PSI Honda Gc190...
Honda gc190 powerwasher
a good spark is one that you can barely see.A tiny blue spark is known to be a hot spark.bright yellow or white is a cold spark and this is not good try a new plug it should be a ngk bpr6es.give this a try and let me know.also do you feel any compression while your pull starting it?
Aug 19, 2014 | Honda Garden
Throttle linkage is loose and when started water does not come out the nozzle after BEING BLED OF AIR
The unloader on your pump is bad...this is causing both problems. Find your pump model # ...probably an AR pump ...they fit the Honda GC engines well and go to this site Pressure washer parts catalog quick links Pressure Washers High Pressure... they can guide you to the correct unloader... Good luck
Jan 19, 2014 | Powerboss 020309 3000 psi 2.5...
Honda gc190
Drain the entire system of all existing gas and get some gas without alcohol in it (do a google search in your area for non-alcohol gas). Get it running on this for a while and it shuld clear up the problem.
Jan 11, 2014 | Garden
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Have a brand new karcher 3000 pressure washer with a honda gc190 motor. Fired it up today, ran about 5 minutes then died. Noticed that gas was coming out of a hose that is attached to the bottom of of...
It sounds like the carborator has a drain ****, with a hose attached so it doesn't get gas all over everything. The reason to do this is to drain condensate once in a while. See if you can find a small drain valve and check to see if it is closed. Then add some more gas and wash away!
Oct 29, 2011 | Karcher G3025OH Pressure Washer
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
