HP DV8000 Laptop Display has a 2" white bar from top to bottom on the right hand side of the screen about 2"inches in. If I hook this up to an extended monitor is is not a problem just on the laptop its self.
    President:
  • 4,070 Answers
Hi! Have you tried reinstalling the video card driver of the laptop? It may be just the issue, because when you install it to another pc it works just fine. It may be just a reinstallation problem but if no luck on this then the graphic/video card may be faulty and this will need replacement. Hope this helps and good luck!
Posted on May 17, 2010
HP Elitebook 2530p switches on but no display
Hello!
Just a quick one or two at the moment. Have to locate the problem then figure the fix sooooo..
1. Please refer to the photo: Note the 'hands', one at the top right and the other at the bottom right of the screen. With the power on and the computer in the normal ready to use mode....
What I suggest you do is hold the bottom right corner firmly, keeping it relatively immovable while, at the same time, GENTLY, and NOT completely, SLOWLY start bringing the top left corner down toward the bottom right corner, actually moving the top barely an eighth of an inch, flexing just a tiny bit...
If the display flickers then, hopefully, it is a loose display cable, usually a flat one that lies under the keyboard and need only be adjusted. a tedious but very inexpensive solution.
Another quick, albeit unlikely fault to check is your battery. I know, I know, it's so obvious but I have to ask: Have you tried using the computer from a DIFFERENT wall outlet, better still, at a buds house?
Let's get these two out of the way before moving on? Let me know! I'll look into recalls, frequent problems, etc....
Jimm
Nov 21, 2012 | HP EliteBook 2530p Notebook
I have just had a new screen fitted to my toshiba c660-10t but now about 2 inches on the right hand side is black like the screen is ended and half the tool bar at the bottom is missing
Go to control panel, select display, click on settings top right, go to resolutions and highlight your mouse over the arrow move one notch to the right and click apply, another window will pop up asking do you want to save these changes, click ok, repeat process until the desired results are reached.
Jun 16, 2012 | Toshiba Computers & Internet
Led screen replacement
Michael,
HP Support > Pavilion DV6-3129nr Notebook PC > Manuals > Service Manual,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=5035702&
(I suggest click on the X at the upper right corner, of the HP -Your input is valuable, small window)
Scroll down, click on the 3rd file down -
HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
Disregard the following if you are aware;
1) This is a PDF file. The computer you are using has Adobe Reader on it, which uses PDF files.
2) After you click on the Service Manual file it may take up to 30 seconds, before the first page comes up.
3) At the top of the PDF file (Header) is the page number box.
It is to the right of the Down Arrow.
You can use the Down Arrow to arrive page by page, to the page you want,
OR,
If you know the page number you can do this;
A) Left-click once in the page number box.
(What is in the page number box will now be highlighted in Blue)
B) Type the page number
C) Press the Enter key.
You can also use the Bookmarks menu to the left.
4) In the header at the top of the PDF file, is also the Zoom In tool ( + ),
and the Zoom Out tool. ( - )
Zoom In increases the view size.
Zoom Out decreases the view size.
In the Bookmarks menu to the left click on the + sign, next to -
Removal and replacement procedures
Now click on the + sign next to -
Component replacement procedures.
Or go to Page 77 - Brightview display assembly
1) Work on a table. Suggest lay a soft static free cloth on the table, to work on. Helps protect the table, and the laptop from scratching.
2) Remove ALL power. Remove the AC adapter (Charger) and Battery.
3) Remove the following in order;
A) Hard Drive Cover - Page 54
B) Hard Drive - Page 55
C) WLAN Module
D) Optical Drive (DVD Drive)
E) Keyboard
F) Top Cover (Palm Rest Cover)
NOTE*
Removing the WLAN Module. (Wireless Local Area Network Module)
First step is removing the two small cables attached to the module.
These cables go through the body of the laptop, and up into the Display Assembly.
In the proceeding steps you'll see the WLAN Module cables thread through the bottom of the laptop; through a space next to the motherboard, go along the Top of the motherboard, and then go up under the Right Hinge, and into the Display Assembly.
The WLAN Module cables go with the Display Assembly, when it is removed.
You have to remove the WLAN Module, in order to start threading these cables through. (After disconnecting them from the module)
Make a note, and if you wish a crude drawing, as to where those two cables attach on the module, BEFORE removing them.
There are TWO terminals on the WLAN Module.
There is a White wire, and a Black wire. (Cables)
The Keyboard is removed so the Top Cover can be removed.
The Top Cover is removed,
1) To finish threading the WLAN Module cables out,
2) To access the Display Panel Cable. (Video Cable),
3) To access the 3 Philips head screws that hold the Hinges, (And Display Assembly) to the body of the laptop.
(One on the Left Hinge, Two on the Right Hinge)
NOTE*
Keyboard:
The Keyboard Cable stays attached to the Keyboard. It removed from a connector on the motherboard. The Keyboard Cable, and it's respective motherboard connector, are special.
The Keyboard Cable is a FFC. Flat Flex Cable,
http://en.wikipedia.org/wiki/Flat_Flex_Cable
(Click on the second photo down. 35 conductor flat flex cable)
The flat flexible cable has NO connector on the end. It just has metal contact strips.
This flat cable slides into the motherboard connector, and is locked into position.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is a small rectangular plastic connector, composed of TWO parts.
The bottom piece is larger. It is the BODY.
The Body has the contact pins.
The top piece is smaller. Rectangular shaped also, but much narrower in Thickness.
This is the Locking Bar.
The Locking Bar is wedge shaped. Designed so that when closed against the Body, it wedges, or locks, the Keyboard Cable in place.
The Locking Bar ONLY moves just a little bit. About 2mm, or slightly larger than 1/16th of an Inch.
IF the Locking Bar is moved TOO far, it will break.
This means motherboard replacement.
The procedure is to use your two index fingernails, and ease the connector open. (Ease the Locking Bar away from the Body)
Some 'techs' use a flat tip Jewelers screwdriver. I Do Not recommend it for your first time. One slip may = broken Locking Bar, or damage to the motherboard.
It's your call.
For this type of ZIF connector, the Locking Bar is GENTLY lifted UP, on the Back side. ( Display Assembly side )
After the WLAN Module cables have been threaded through, and are hanging loose, and after the Display Panel Cable has been disconnected, (Only plugs in one way. No worries), the Hinge screws are removed.
Remove one of the two Philips head screws from the Right Hinge.
Hold the Display Assembly.
Remove the other screw from the right Hinge.
Now remove the screw from the left Hinge.
Gently lift up on the Display Assembly, and ensure that nothing is still attached, before removing it.
Display Assembly removed:
At the bottom two corners are screws. They are covered by a Screw Cover. A rubbery cover that has a type of rubber cement on it.
Gently pick the covers off. I use a computer pick. You may wish to use a device that is similar.
If you are careful, you can reuse these covers. Lay them upside down on a flat surface. (Yes. They like to stick to the tool, and your fingers)
Two Screw Covers removed, remove the screws.
(Use a multi-compartment container, for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise do NOT mix them up )
The Hinge Covers are U-shaped. Pop them up, and off.
The Display Bezel is the thin plastic frame in front of the LCD screen.
Resembles a picture frame.
It is pretty flexible, and pretty tough. (Space-age plastic)
Removal method is to use your fingertips, and flex the inside edges, of the Right side, and Left side.
Flex the inside edge up a little on both sides.
The Display Bezel snaps into the Display Enclosure.
(Laptop closed looking at top. That plastic cover is the Display Enclosure)
There are tabs on the Outside edges of the Display Bezel, and matching tabs on the Inside edges of the Display Enclosure.
When the Display Bezel is removed, there is a snapping sound for the release of the tabs.
If gently flexing up on the inside edges, Left and Right side, of the Display Bezel is not working;
Flex the middle of the inside edge, UP, of the Left side of the bezel.
Carefully work a finger towards the Top. The tabs should start releasing.
Now do the same for the Right side of the bezel.
Go towards the bottom now.
After the Display Bezel is released, you may have to slide it a little bit, one way or the other, to remove it. (Latch)
Display Bezel fully removed, there are 6 Philips head screws to remove from the corners of the Screen Frame, of the Display Assembly.
These screws hold the Display Assembly TO the Display Enclosure.
ONE screw at the Top two corners, TWO screws at the Bottom, for each corner.
EASE the Display Assembly up. DO NOT go too far. You have to disconnect the Display LED Cable, from the Display Panel Cable.
Now remove the Display Assembly.
Remove the Display Hinges from the Screen Frame.
(The metal frame that surrounds the LCD assembly, is the Screen Frame.
Note* The LCD screen is an assembly. It is composed of layers, and these layers are aligned by the factory. Then the Screen Frame is put around the layers )
Note*
There are 6 screws to remove in order to remove the Display Hinges.
3 on each side, (3 for each Hinge)
There are also screws which can be removed, and this will take the Screen Frame apart.
Suggest ONLY remove the Hinge, to Screen Frame screws.
Carefully remove the sticky tape, (REAL sticky), from the Display Panel Cable, where it attaches to the LCD screen (Assembly)
Now you can carefully disconnect the Display Panel Cable.
Reverse these steps to replace the LCD screen.
(The LED Backlight is a series of LED lights. They are an integral part of the LCD screen assembly)
Please dispose of the LCD screen properly.
Observe the routing of the various cables through their respective channels, and latches. They MUST be reinstalled in the SAME routing.
(WLAN Module cables, Display Panel Cable, Webcam cable, Microphone Cable, etc)
If you do not own an ESD wrist strap, I would advise buying one, and wearing it. (Also make sure it's alligator clip is connected to a good ground source)
The average cost is around $3 to $6.
Just one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components, of a computer.
Wear an ESD wrist strap, with it connected to a good ground source, and your laptop is SAFE.
It isn't the Display Assembly side that concerns me so much, as the motherboard side after the Top Cover is removed.
Two disassembly pictorial guides that may help. It's for an HP pavilion DV6 series of Notebook PC, but differs slightly from your particular model,
[ Top Cover for yours is all one piece. No separate Switch Cover.
No screw covers, and screws next to the base of the Hinges. (At the Body of the laptop)
There are 3 screws that hold each Hinge to the Screen Frame, not 2 as in the article. { LCD removal)
Shows good detail for unlocking the Locking Bar.
Guitar pick is a method I use sometimes. May be best for you ]
1) Removing the Display Assembly;
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/
2) Replacing the LCD screen;
http://www.insidemylaptop.com/replace-broken-screen-hp-pavilion-dv6-laptop/
For additional questions, comments, or to have me clarify anything I have stated, please post in a Comment.
Regards,
joecoolvette
Mar 17, 2012 | HEWLETT-PACKARD HP Pavilion dv6-3129nr...
Laptop says "wireless hardware not
Hi
i believe that when looking at the screen
look at the very bottom right hand side
then look just below the screen on the very top bar of the keyboard
on the right hand side you may see a push key with a picture of what looks like a small satallite
push once and wait a few seconds and it should enable and then show a blue light
push again and it should disable
many thanks
Aug 29, 2011 | HP Pavilion dv4-1430us Notebook
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
If we close the screen a little bit it goes bright white. Have to switch off and restart. Also, after doing a power point presentation the display is only opening about 80% of full screen with a black...
In LCD screens is a common problem that after setting a lower resolution than recommended you'll see a black stripe sometimes up and right, right click on any empty spot on your desktop and select properties then go to display options and move the resolution bar to a higher point and click apply also click yes in the warning display and accept.
Regards.
Jun 15, 2009 | ASUS A6Ne Notebook
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
ZD7020US Display
sounds like you have the wrong monitor drivers installed,  download updated monitor drivers from the manufacturer's website,
also check your display settings,  as something is really wrong there.
Oct 17, 2007 | HP Pavilion zd7020US Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
