Question about Acer Aspire 5315 15.4-inch Notebook PC
No audio when connecting Aspire 5315-2326 to TV.
When connecting my Aspire 5315-2326 to the tv through 4to4 pin S Video cable I get video but no sound. Tv is 4 pin Lptp is 7. What connection and/or setting is required to have the sound go to tv as well? Have headphone and mic jacks on front of lptp & RedYelWhite on TV. The TV is JVC projection...Haven't looked in back for pc connection but suspect there is one...Laptop also has 15 pin on left side.....
  • 86 Answers
Use a cable out of the headphone jack with an adapter to the red and white (left and right) audio jacks of your TV.
Posted on May 16, 2010
How do I hook up my 55 inch led tv to a stereo for better sound
In many cases newer tv's do not have an audio out, some have a headphone jack on the side (Small usually blue)
Otherwise if you are wanting to get better sound from a DVD / Blueray / Satellite / Cable box, You can put the audio from these devices into your sound system, then plug your sound systems audio out into the tv.
The video out from your devices will need to connect directly into the tv.
If using HDMI or S-Video that carries both audio and video, slitter / separation boxes are available, but usually degrade sound and audio quality.
The above would look something like
Cable box audio out (red / white) to Stereo audio IN. >> Stereo Audio OUT to TV audio in.
Yellow (Video) Cable from cable box then goes directly to the TV Video IN. Just make sure the audio and video cables are going to the same section (Some tv's may have multiple audio / video in's
Nov 17, 2014 | Haier LE55B1381 55 Class LED HDTV - 1080p,...
Cable to connect laptop to TV
VGA from the laptop to whatever the TV takes.
Mar 19, 2014 | Computers & Internet
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
Not able to connect my Acer Aspire 4720Z notebook to TV
You will need to change the TV's input select to S-Video to view your notebooks display. Remember S-Video is just that, Video and no sound. You'll need to patch the audio in via Audio In input on the TV if you haven't already?
Jul 22, 2009 | Acer Aspire 4720 Notebook
Connection to my old TV
your tv do not have an audio/video input...what you need is a device called RF modulator, it converts the audio/video signal from your dvd player into RF signal similar to the signal from the cable operator.it has an audio/video input and a coaxial cable output..
Jul 18, 2009 | Curtis DVD1047 DVD Player
I do not know how to hook up my goldstar to my TV. My daughter gave me the dvd/vhs that was hers. Are there instructions?
The power cord of the DVD to be connected to the power supply.
the audio cable goes from the audio pin from the DVD player to the TV audio pin.
The video cable goes from the video pin from the DVD player to the TV video pin.
Jul 05, 2009 | Goldstar GBV241 DVD Player/VCR
Sound from my tv card, skydude doesnt work on my hp laptop, vista home premium
You haven't mention about the connections you have with the SKYDUDE TV box. TV boxes usually have AV (audio and video) connections i.e., two seperate connections for audio and video signals. If you are using a set top box to connect to the tv box you can connect the "video out" of the set top box to the "video in" of the tv box using a cable. and "audio out" of the set top box to the "audio in" of the TV box using another cable. Some TV boxes don't have the "audio in" option. In that case you have to connect the "audio out" from the set top box directly to the "audio in" of the computer. This pin you can find just near the "speaker" and "mic" connections.
If you have an S-Video pin in your TV box, you can use an adopter wire to connect two "audio in" and one "video in" connections to the same pin. And you have to select S-Video option in the software installed.
If you have "RF in" option in your TV box, you can use use AV to RF converter to connect your set top box to the TV box.
Thank you,
Apr 25, 2009 | Computers & Internet
Acer Aspire 5315 15.4-inch Notebook PC   Logo
312 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
