Question about Acer Computers & Internet
My key board layout has some of the keys on opposite positions ie; shift-@ is shift - '' how do i chnage the layout of my keyboard?
em0ti0n1
  • 35 Answers
SOURCE: acer 240 laptop keyboard took sip of coke
Proper cleaning and lubrication as described here will restore your laptop keyboard to the snappy and smooth performance it had when new. This will require about 2 hours time once you have collected the proper cleaning materials.
Cleaning materials:
  • Cotton swabs
  • Cosmetic foam rubber cleaning pads ( use only with naptha (lighter fluid), NOT alcohol)
  • Paper towels
  • Rubbing alcohol
  • Water
  • Lighter fluid (naptha)
  • Fine tipped tweezers
  • Scissors
  • Kitchen strainer
  • Household cleaner, Windex or equivalent
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive. This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows:
DISASSEMBLE
IMPORTANT: Make a keyboard map so you know where each key goes.
Carefully pry each key loose with a small screwdriver and place in a container. They pop off. DO NOT use excessive force. There may be a small rubber piece for each key. Remove all of these and place in a separate container. CAREFUL, these are small and like to jump away.
CLEAN KEYBOARD
Do this well...... you will be wonderfully rewarded
Clean the keyboard with cotton swabs SLIGHTLY DAMPENED with water. Replace these often and BE SURE they are only slightly damp. If they are too wet the excess water will contaminate the keyboard through capillary action. This will clean all water soluble contaminants like Coca-Cola, coffee, and sugar residue. For the very small places, cut the foam rubber into small pieces and use the tweezers, again SLIGHTLY DAMPENED, for cleaning. You must clean each and every key space, inside and out, this is critical since this is where the key touches and moves.
Repeat this procedure again using rubbing alcohol and cotton swabs but NOT the foam rubber as it disintegrates when used with alcohol.
Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SCACE BAR.
CLEAN KEYS
Some keys may have wires attached and some grease on them, clean these first with cotton swabs and naptha (lighter fluid). Remove all traces of the grease.
Place all keys in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Rinse thoroughly with hot water and place keys on paper towels to dry. Let dry completely.
CLEAN RUBBER COMPONENTS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don't lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely. LUBRICATE KEYS
Place all keys bottom-up on a paper bag. Lightly coat the keys, at a 45 degree angle with Super Lube Dry Film lubricant. Do this from all 4 sides to assure penetration and coverage into the small and critical guide spaces inside each key. Let dry ( this happens nearly instantly). DO NOT overdue this step as the carrier solvent may affect the plastic.
LUBRICATE KEYBOARD
Mask off the laptop with paper and scotch tape. Apply lubricant (as above in LUBRICATE KEYS) to the keyboard and let dry.
Alright, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE
Place all rubber components into the keyboard.
Install keys with wires. Make sure wire is secured in the key, usually snapped into place. Place ends of wire in the guide slots adjacent to the key location as you align the key. Firmly press down to snap the key into place.
Install the rest of the keys by aligning and firmly pressing down.
CONTRATULATIONS, you now have a squeeky clean keyboard!
Posted on Jan 12, 2009
mikeleach
  • 48 Answers
SOURCE: problem with toshiba laptop keyboard pressing wrong extra keys
Take the keys off yor keyboard, clean and remove and dirt, replace keys and try again
hope this helps
Posted on Jun 07, 2009
SOURCE: LG r700 green keys wont turn off when using shift key in outlook
I was having the same problem - it was just driving me bananas. I figured it was a keyboard language, but when I checked my default it was still English (Canada) - US. I Tried the keys to switch between languages, I turned on and off the hot keys for input languages - all to no avail. FINALLY - I added a floating language bar to my desktop, and what do you think it was set at? That's right - bloody "Canadian French." I simply switched it back to "US" and problem solved. Now I just have to remember that for next time. . . . .
Posted on Oct 06, 2009
mahhek
  • 662 Answers
SOURCE: I have a Toshiba Satellite with an American
For a workaround for time being you can use the OSK (on screen keyboard to get a backslash) which can be accessed by pressing the Windows key and the letter "U", or you can go to start > Run and type "osk". Meanwhile I will try to get a proper resolution for this issue. Wait for my reply.
Posted on Nov 11, 2009
Testimonial: "Thanks very much, need to map a network drive urgently - this will do for now. "
parrotheadpc
  • 2600 Answers
SOURCE: how can i make a forward slash on a mexican
On these keyboards, the non colored symbols are typed by holding down the shift key and tapping the symbol. If you want to type the colored key, then you have to hold down the Alt Gr key and tap the colored symbol key.
Posted on Jan 13, 2010
Why is it that when i type the letter A would type a Q an B would be an V
thee are 2 keyboard layouts in use and they have the letters in different positions
find the key board settings and change it to american key board layout or opposite to what it is now
May 06, 2016 | Irulu 10.1 inch Android 4.2 Tablet PC,...
Keys need remaping
Check to make sure you have the location settings correct in your computer as different locations around the world use different keyboard layouts. I.E. US keyboard layout is different the Great Britain layout.
Feb 26, 2014 | Toshiba Equium A110-233 A110-252 A110-276...
Acer solution center
Make sure in your settings that they keyboard layout is set to the correct keyboard layout.. I.E. if you US it will be US English keyboard layout..
Dec 01, 2013 | Computers & Internet
How to type the @ key - it is on a key with " and 2 - when I hold down shift key either the " or 2 print but not the @.
Did you tell the operating system to have the keyboard be another language other than english?
Remember its nice to change the language if you need you "ninas" or dashes, but if you need that @ sign you need to change the keyboard language back to english.
Mar 05, 2010 | Acer NSK8458AN Keyboard
The keys are not synchronised properly. The @ key and the " are typing each others symbol. ie I have to press shift 2 to get the @ symbol and vice versa.
you are using a usa keyboard.
if you want to use the uk keyboard layout change the regional settings, go to languages and there is an option to change the keyboard.
uk keyboard will print " when pressing shift+2
Jan 12, 2010 | Dell 0Y3740 Keyboard
Key board problem
It would seem that the keyboard may be defective. It is a fairly standard keyboard layout, so SHIFT-2 should produce the @ sign. It looks to be a fairly cheap fix:
http://cgi.ebay.com/New-Keyboard-for-Acer-Aspire-4520-5315-5520-5720-5920-_W0QQitemZ390088823197QQcmdZViewItemQQimsxZ20090901?IMSfp=TL090901179007r413
Sep 18, 2009 | Acer Aspire 5720-6661 Notebook PC
The upper case figs ie @ and " have swopped positions how do i get them back to their right postions
The difference in the @ and " symbols occurs between US and UK keyboards, where UK keyboards have the " symbol on the "2" key and US keyboards have the @ symbol on the "2" key.
Regardless of what physical drawing you have on the keyboard, you can change the actions of the keys by setting up the appropriate US or UK keyboard layout in Windows.
First, determine whether you'd prefer a US or a UK layout. In the US layout, pressing SHIFT+2 will write @. In the UK layout, pressing it will write ".
Now, from the Start menu, select Settings and go to Control Panel. Once there, search for "Regional and Language Options". Under the "Languages" tab there is a button labeled "Details". Press it, and a new window opens with the keyboard layouts. Use the "Add" button to select the keyboard layout you want (English, US or UK, Qwerty - not Dvorak), then Remove your old keyboard layout. Press OK and exit all the screens, you're done.
Hope this helps.
Aug 13, 2009 | Compaq Keyboard
Keys swapped
ok you do not have a bad chip - check you keyboard settings I have both an American keyboard and English upgraded, but like the keys where they were (English settings so i have English keyboard with an American keyboard therfor to get it back (tell me if I am correct please).
go to start In Win XP, to change the keyboard languages and layout, click Start , then choose Settings, Control Panel, and Regional and Language Options. Click the "Languages" tab, then the "Details" button, I hope this helps
Mar 17, 2008 | Logitech 967437-0403 Keyboard
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
