Question about Cerwin Vega LS-15 Speaker
I need to find a 15in woofer for a old set speakers.D-15EE into 4ohms
    Brigadier General:
  • 8,546 Answers
Tralaua soundstream 15in 1000 rms best way to wire subs for loudest sound
Best thing to do is build the right enclosure. Which woofer exactly as you need the Theile/Small parameters to calculate the correct vented enclosure. That will buy you more than any wiring setup. Typically 15 icnh woofers like to see about 5 cubic ft per woofer to really get loud. And it all depends on your vehicle also. Need more input to help out, like what amplifier, whioch woofer specifically, vehicle your putting it into.
Jun 02, 2014 | Car Audio & Video
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
I have 3wayboxes with a 15in sub 1intweets and3in med could i just use theme and not front speakers
you could, but your sound image would be heavy in the rear, why not use the boxes and the front speakers?
Jan 20, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
Sep 07, 2009 | Eclipse EA3422 Car Audio Amplifier
What speakers
Hello enot99,
The CC-2502 is a bridgeable 2-channel amp. If you want to drive normal speakers in stereo, the best would be a good set of components with separate woofers, tweeters, and crossovers. They are available in many sizes from most car audio manufacturers. I'd begin by finding out what speakers fit the location where you intend to mount them. Then I'd browse the speaker selections in that size at www.crutchfield.com. You can also use the "outfit my car" feature to browse only the products that fit. Then select a pair that has a power range and impedance to match the amp: 250 watts RMS at 4ohms or 450 watts RMS at 2ohms.
If you want to use the amp in bridged mono mode to drive a subwoofer, again Crutchfield has a large selection of subs and some enclosures already fitted with subs (loaded). The amp claims 850 watts RMS into 4ohms bridged, so look for a sub that has a power handling rating of at least 850 watts and it needs to be 4ohms.
Hope this helps.
Aug 02, 2009 | Concept CC-2502 Car Audio Amplifier
My car's sub is ''sub-par'' my expectations
Hello css42103,
You did not specify the impedance or the model of your Audiopipe replacement woofer but if it is the TS-V6 DVC 6.5", then the impedance of each voice coil is 4ohms. If you wired the coils in parallel, you now have a 2ohm load to the amp. At 2 ohms, the amp tries to produce more power, and even at moderate volume, can be driven into clipping causing distortion. Not good for the amp. Definitely not good for the woofer.
I'd try wiring the woofer coils in series and see if it stops cutting out.
Hope this helps.
Jun 01, 2009 | Car Audio & Video
Need woofer for B2030A
Check the watts and size on your old woofer and go to radio shack and get a repacement woofer with the same wattage and size.
Radio shack make great replacement speakers and woofers.
Feb 14, 2009 | Audio Players & Recorders
Home theater system protection kicks out
Nice write-up.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
On page 6 of the manual it states you should use a powered subwoofer and the unit provides a sub output on the rear panel for it. The message from the amp kicking out is that you're not going to get away with your workaround.
I would advise you to purchase a nice amplifier (2-channel bridgeable or single channel) for the subwoofer. That way you'd be sending only LFE signals and your receiver has provisions for adjusting its volume relative to the rest of the channels. I use a nice 5-channel Carver for my 3 subs and both Rear Surrounds.
On eBay I see what I would get if I were you - a Carver M-200T (120W x2; 300W bridged). I have one.
http://cgi.ebay.com/Carver-Magnetic-Field-Power-Amplifier-M-200t-120WPC-Amp_W0QQitemZ200327110781QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item200327110781&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
Mar 02, 2008 | Sherwood RD-6500 Receiver
Cerwin Vega LS-15 Speaker Logo
196 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
