Question about LG DLE2532W Electric Dryer
LG TDC70080E Dryer runs and afetr a few minutes there is a smell. Opening the dryer i find water in the condensate tray. I have checked the pump and i looks okay. can any one help?
    Problem Solver:
  • 4 Answers
The TDC70080E doesn't have an exhaust vent.
Does the display show any messages? e.g. clean filter?
...and you have cleaned all the various bits but it still cuts out after a few mins of running?
It is most probably the motor which is knackered.
Have a look at this:
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=51978
A new motor from SEME Nedis (www.allourparts.com) is about £40.
If you can hold a screwdriver and a sokect wrench, you can fit the motor yourself. It's really easy. Just unplug it from the wall first!
Good luck.
Posted on Feb 19, 2010
  • 489 Answers
You have a plugged exhaust vent in the house wall.  Remove the vent from the back of the dryer and run the dryer.  The problem should go away.  You will need to call a qualified vent cleaning company to remove the lint restrictions inside the wall.
Posted on May 02, 2008
SOURCE:
Beko tumble dryer ecogentle model seems to be working but not removing moisture from clothes no water in condenser tray.
Is there heat? Could be running cold if the elements have burnt out. If there is heat then check the pump and float switch that pumps the water from the sump into the condenser tray
Oct 13, 2018 | Dryers
LG Washer Dryer F1403RD low drying efficiency. Any ideas
If it’s taking a long time to dry, check venting for obstructions or kinks.
Condenser dryer
PULL OUT THE PLUG
on the bottom right on the back is the water pump
it needs cleaning or replacing
not lifting the water to the water draw
Dec 12, 2013 | Creda IWD12 Front Load Washer / Dryer
My Bosch wtl6304 condenser tumble dryer keeps indicating empty filter light and bleeps rapid. It warns me twice like this then trips the thermostat out. I have cleaned filter, washed the condenser out and...
never really heard of a condenser model dryer before however it does seem like internally its full of lent inside of the dryer housing itself around the heating elements if you have a large air compressor open it all up and spray air into everything in the dryer where you see lent build up this will force any lent out of the dryer and it should hopefully run as the day you first got it ;P found this to be an issue even with an LG TROMM dryer i opened up and wasnt drying very well
May 06, 2017 | Bosch Axxis WTL 6307 Electric Dryer
My condenser tray is not filling up with water but the dryer is still working. where is ther water going and why do my clothes smell ?
I have the same problem, my water is gathering behind the condenser unit but it's stopped drying the clothes aargh!!
Jul 12, 2009 | Hotpoint TDC32 Electric Dryer
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
I have an LG TDC70080E condenser tumble dryer. It has worked perfectly for 2.5 years and now is playing up (suprising, considering it is just out of warranty!) There are two issues: 1. The drum is not...
My pump started making a loud noise and stopped pumping, I removed the pump and found that the impeller had moved down the shaft, so I put some locktite on shaft replaced impeller and its fine now
Oct 28, 2008 | Dryers
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Jul 25, 2007 | LG DLE2512W Electric Dryer
LG DLE2532W Electric Dryer Logo
122 people viewed this question
Top LG Dryers Experts
jimorris77
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
