Question about InFocus IN24 Multimedia Projector
Will not find the source
It will not read the computer connected
    Problem Solver:
  • 11 Answers
Fn + F2 = :)
Posted on May 17, 2010
It saying .. No Sync what does that mean?
No Sync indicates that the input signal doesn't match the type of signal that the TV can read. A digital source going to an analog input could cause the issue.
What is your source for the signal?
If you are using the DVI connection on the TV to connect to a computer, try using the VGA input instead. Unfortunately not all TVs can interpret the computer's digital signal. (It is different than the digital signal from a set top box.)
The manual for the TV is available from the product site: http://insigniaproducts.com/products/televisions/IS-LCDTV32.html . The direct link to the manual is: http://insigniaproducts.com/cms/documents/IS-LCDTV32%20UM%20EN_SP_FR.pdf .
Please add a comment with your source and I will offer additional suggestions for solving the error.
I hope this helps.
Aug 02, 2011 | Insignia IS-LCDTV32 32 in. Television
After switching on the projector displays message 'searching for source' then 'no source found'. Computer is connected to Optima EP7155 using vga cable.
1 check VGA cable for damage (try other cable)
2 check connections
3 make sure you have resolution on PC is faling in projectors resolution range
4 if it is laptop, make sure you have it in external monitor mode (usually Fn + F8 keys)
Mar 01, 2011 | Optoma EP7155 Projector
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
How to i see my own picture in the webcam ?
You will need a programme that is able to read an image source on your laptop.
Debut is free and a compact software package that reads any image source connected to your computer.
http://debut-video-capture.en.softonic.com/
Jan 09, 2011 | Fujitsu LifeBook A6110 PC Notebook
Computer shuts down
Please visit the below link to solve your problem.Due to some problems I was unable to send you the whole solution so please visit the site.
http://www.ehow.com/how_113600_troubleshoot-computer-wont.html
Thanks And sorry for the inconvenience.
Please rate me for this solution if it works for you.
  • Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szt64gb5
  • Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  • Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szsjH6o9
    Jul 06, 2010 | Dell Inspiron 530 Desktop Computer
    I have toyota prius, As I start car, master warning light, dischrge warning light, ign and malfunction indicator light come. what do i do to fix these problems?
    your car is reading errors from different source and the best and most effective way to tackle this is to start by having a diagnosis test on it.It consist of a connection connected to a computer which will then read and allow you to erase/reset or read error codes.Once you get the codes then you know where to start looking.Hope this helps.
    Feb 01, 2010 | Samsung (SD-612) Internal DVD Drive
    Samsung T220HD - can't access HDMI input sources
    If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck.
    May 09, 2009 | Samsung T220HD LCD Monitor
    Dvd cd rom not reading anything on my Dell computer
    Having to use a paper clip instead of the eject button working could indicate a power source problem. Not reading anything on the drive could be either power source, connection cable or motherboard. I would start by removing the drive and checking all connections. You did not state if this is a laptop or desktop. If it is a desktop, there should be several unused power connections.If you do not have the ability to check the used connection, just switch to a different one.Also check the connection cable to the motherboard and if possible change or replace that. If all this fails, I would assume from a distance that the DVD drive is defective and try to replace it.
    Dec 17, 2008 | Dell DVD-ROM for Dimension (6t903)...
    Dnx7100 ipod problem
    The USB source is not for Ipods, from what I understand. The Ipod needs to be connected with the Ipod cable, $50 or so. I think it is a high speed connection.
    Jul 07, 2008 | Kenwood DNX7100 Car Video Player
    Insignia 42" LCD resolution > 1280x1024 w/ computer source
    Salutations RandomDrone,
    From reading your owners manual it appears the max resolution of the television would be 1280X1024 when using the VGA connection.
    If you would like to review the manual it should be available at:
    http://www.insignia-products.com/skins/skin_1/Topics/Documents/07-290%20NS-LCD42HD_WEB.pdf
    Sorry, I didn't have better news.
    Jon
    Go Ahead. Use Us.
    Jun 01, 2008 | Televison & Video
    InFocus IN24 Multimedia Projector Logo
    50 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
