REMOVING THE FILLER CARD TO INSTALL A MODEM
I HAVE A DELL DESKTOP COMPUTER, MULTIPLEX GX620
HOW DO YOU REMOVE THE FILLER BRACKET IN ORDER TO INSTALL A MODEM. IT LOOKS LIKE IT IS JUST IN A SLOT AT THE BOTTOM & UNDER A CLIP AT THE TOP. I CAN'T FIGURE OUT HOW TO GET IT OUT.
BOB BLACK
MAPAB1@JUNO.COM
  • 36 Answers
For any Dell hardware problems, please visit http://support.dell.com. You will see flash animations on how to remove and fix system.
Take care.
Posted on May 09, 2008
Hello, I have a Dell Optiplex GX620 desktop
I would remove the new card, and recheck vol. Next, change PCI slots. Pick up a cheap audio card and see how works. Good,luck
Oct 19, 2013 | Dell OptiPlex Computers & Internet
Dell optiplex gx620 orange color on the sturt boton
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 21, 2012 | Dell OptiPlex GX620n PC Desktop
I HAVE A DELL GX620 DESKTOP COMPUTER IM TRYING TO INSTALL NEW WIN XP I GET A MESSAGE SELECTED BOOT DEVICE NOT AVAILABLE HOW DO I FIX THIS PROBLEM ?
Place your windows XP install disc into the dvd drive. Turn your desktop off. Then turn back on and tap F12. Then select your dvd drive instead of the HDD. This will boot your computer from the disc data instead of your HDD data.
Hope this helps
Mar 04, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
My dimension 3100 is not detecting a modem
Sir,
Respectfully please first check if there is a modem in the desktop PC since the dimension 3100 is not pre-equipped with a modem. you have to attach an internal modem manually on one or more PCI slots on the mother board.
the process is given here....
  • Turn off the computer. Unplug the power cord from the electrical outlet. Disconnect the power cord, attached peripheral devices and any other cables.
  • 2 Locate the cover release latch on top of the computer, near the back. Place the computer on its side, with the removable cover facing upwards. Slide the cover release latch back and lift the removable cover off of the computer. Set the removable cover aside.
  • Locate the PCI and PCI Express slots near the bottom of the system board. Select a slot that corresponds with your internal modem card. Open the card retention door on the back of the computer and remove the filler bracket for the card slot you will be using.
  • 4 Place the internal modem card into the appropriate card slot and press it firmly into place. Close the card retention door. Replace the removable cover and return the computer to an upright position.
  • 5 Connect one end of the telephone cord into the LINE port on your internal modem card; plug the remaining end into a telephone jack. If desired, connect a telephone to the internal modem card via the PHONE port.
  • 6 Reconnect the power cord and all previously disconnected cables. Plug the power cord into an available electrical outlet. Turn on the computer. If any installation software came packaged with the internal modem card, run the program and follow the onscreen directions. Your internal modem is now ready for use.
  • May 06, 2011 | Dell Dimension 3100 PC Desktop
    Add in slots
    if you are talking about pci cards and all of that you have to open the computer from the side removing the screws on the back and sliding the cover towards the back of the CPU. After you remove the side, check the filler you want to remove and there is just 1 screw that holds each one of them, remove that screw and pull the filler out. that opens the bay for you to install a modem, pci card etc.
    if it works for you don't forget to rate me
    thx
    May 03, 2010 | E-Machines eMachines Desktop PC
    Sound of my pc removes after 5 mins from installing drivers. my pc is dell GX620
    if you have reinstalled corect drivers from the dell website
    or the cd that was supplied with it, there shouldnt be a problem.
    If your using a operating system that was not made for these cd drivers you could have conflict issues, search for card make and os that you are using now maybe there is update.
    Since the card does work for 5 minutes, and then stops it could be a possible short in the wiring to speakers or amps. make suire there is no shortages that can cause the card to over heat and trip out. hope this helps
    Nov 28, 2009 | Dell OptiPlex GX620 PC Desktop
    Installing a network card
    Make sure the slots line up perfectly. It should be pushed firmly and evenly into the slot. Make sure that the metal bracket is not in the way or hitting anything else.
    Oct 26, 2007 | Dell OptiPlex GX110 PC Desktop
    Computers & Internet Logo
    83 people viewed this question
    David Payne
    David Payne
