Question about Lowrance Lcx 28c Hd 7" Gps Fish Finder Combo With 200 Khz Tm Transducer
Soner picking up down riggerball - Lowrance Lcx 28c Hd 7" Gps Fish Finder Combo With 200 Khz Tm Transducer
    President:
  • 2,030 Answers
The unit will pick up anything in the water.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on May 16, 2010
  • vmwltd2 May 16, 2010
    I have friends with diffrent lowrance or garmin that dont have this problem
  • Sean Wright
    Sean Wright May 17, 2010
    Well I would suggest that you check the positioning of your transducer and that it is properly installed and aligned as per the manufacturers directions.
K770i sim ic location in board
i want to know sonyericson sim ic location in board.pls show me now
Apr 05, 2012 | Sony Ericsson Cell Phones
Sony trinitron xbr (9 years old) failing to power up
Turn it off u leave on to long ur CRT Tube will dies soner.Resolder the FBT,the flyback transformer, the big block of plastic with a red wire with a cap hook to the and the transistor beside it.This transformer is the HV to the CRT to get power.
Jan 15, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
My t.v. flickers in and out of color, currently black and white.
U know how to soldier?Might need resoldier the video board pins joints.
Resoldier the yoke connection pins to the main board too.
If ur tv it in use for a long time would hurt to change the bulbs.
U have to soner or later.
Aug 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Timing after recording. and midi composing
May I suggest you try to adjust your audio settings inside Sonar. Also it is a good idea to always keep your C drive well defragmented. I once had this problem using Sonar LE and the only way I got rid of it was after formatting my C drive and reinstalling the drivers and Sonar again. After that the problem came back and then I upgraded from the SB Live to Audigy SE.
Make sure you also have lots of free space on your C drive and have a decnt amount of ram.
May 11, 2009 | Cakewalk SONAR 4 Producer Edition for PC
I need Sony Ericsson G502 Driver for Vista
download sony ericson pc suit updated version. i am using this
Mar 11, 2009 | Sony Ericsson G502 Cellular Phone
Phone code on p990i
i can not open my inbox for sony ericson p990i
Mar 04, 2009 | Sony Ericsson Cell Phones
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Ge side by side refer, no model number available at this time
a flashing DE usually indicates a defrost problem on any unit, they don't flash indicating they are in defrost, soner or latter the problem will show. You could have an intermittant bi-metal or most likely it being a ge - a bad defrost heater. and there is always the possibility that it could be the board. It would have to be trouble shot properly
Aug 04, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Lowrance Lcx 28c Hd 7" Gps Fish Finder Combo With 200 Khz Tm Transducer Logo
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
