Trendware TRENDnet TE100-P1U Print Server
Problem for Trendware TRENDnet TE100-P1U Print Server
Trendnet TE100-P1U won't print
By net_noob on Mar 31, 2008
I followed the directions in the quickguide. Everything looked fine. I printed the Test Page and it said it was successful, but nothing printed.
I checked the print queue through Device Manager and it showed the test page with the status "printing". It would not allow me to cancel the print job. I tried to remove the printer (in Device Manager) and it wouldn't remove it. Maybe that is due to the print job that I was unable to remove. I made several of these network printers in my attempts to print but now I can't remove them because I tried to print the test page. how do I get rid of them?
What is Trendnet looking at when it says the test page printed successfully? Did it actually see that it sent the print job to the printer? What is going wrong here? I have done the Trendnet procedure several times and I even downloaded the latest printer driver (Lexmark x5250 inkjet all-in-one) but I can't get anything to print. When I move the USB cable from the printer back to my desktop it prints just fine.
I appreciate any help I can get. Thanks.
Best Solution
posted on May 10, 2008
Very Helpful)
scot341
Rank: Apprentice
Rating: 97%, 3 votes
open the print server utility and the doc can be cancelled or deleted from there. (this is the server utility inthe toolbar at the bottom of a windows screen. failing this go to the printer shortcut and from control panel>printers> select printer and faxes>select the printer (open) >select "printer" from menu bar, pause printing,then cancel all documents. Afterthis you can delete printers that are excessivly created, or delete all of them and start again with only the one or two printers you need. even if one is for network use and the ther is direct connect. You canuse direct connect to verify proper printer operation until te100 is working properly
Was this helpful?
Yes
No
Popular Solutions for Trendware TRENDnet TE100-P1U
Questions and Unsolved Problems for Trendware TRENDnet TE100-P1U
Do you recommend Trendware TRENDnet TE100-P1U Print Server?
Answer
Answer
I can't print from any of my pc's on my router except the test file in the PS-utility. I also cannot... (More)
Answer
I've connected my trendnet on a LAN via a switch. The LED light is on on the trendnet and it's... (More)
Answer
I have the same problem. My laserjet 1018 appears offline in the trendnet TE100-P1U and... (More)
Answer
The utilities that came with the print server install OK, but get an error when attempting to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Trendware TRENDnet TE100-P1U...:
Top Print Server Experts
Rank: Guru Guru
Solutions: 3634
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Print Server Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
