Question about Craftsman 24 Hp 48" Deck Yard Tractor
Mower starts, but won't move
Starts OK, but then won't go forward or reverse. Deck is disengaged and at Level 6, parking brake is off.
What seems to be the issue?
  • 33 Answers
I would first look at the drive belt for damage or to see if it has derailed.
Posted on May 16, 2010
  • K. Wackley Jul 04, 2013
    drive belt is fine
Husqy cth2542 starts and can move both in forward and reverse and seems to rev fine, but as soon as the blade is engaged) the engine looses power and turns off if the blades are not disengaged.
It sounds like a safety switch issue. It may be possible one of the deck PTO safety switches has gone out or the connector plug is loose or broken. Some newer mowers have fuses located either somewhere around the dash or under the seat check to see if there are fuses and if one is bad it could cause a similar problem to a bad or disconnected safety switch
Jan 01, 2017 | Garden
Tractor seems locked in gear wont go forward or reverse and wont start
push dowm on clutch/brake and let it up releases the brake . has to be pushed down to start though
Jul 13, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
X type will not reverse
Check your trans fluid. Look in the Owner's Manual to see if you have the shift interlock override/bypass button available. This allows the shift lever to be moved w/out pushing the brake pedal.
ENSURE THE PARKING BRAKE IS SET before trying this.
If it moves w/the shift interlock disengaged, it's likely an issue w/the shifter - not the transmission, but since it's a Jag....well, you're probably going to have to sell a kidney!GL,Td
Oct 03, 2012 | Jaguar Cars & Trucks
2000 Mazda MPV Starts & runs won't go out of Park Shifter handle moves won't change gears??
I had this issue in the past. All I did was to replace the brake switch. This part is located behind the brake pedal. Btw, if you this run into this issue again in the future, you can always push this switch with your finger and it's located on top of your steering wheel enclosure, this will disengage the shifter.there is a small rectangle shape cover that you need to remove first.
Aug 08, 2017 | 2000 Mazda MPV
How do I disengage a locked parking brake on a 2001 Ford Taurus wagon? I left the car sitting with the parking brake engaged for a long period of time and now it won't disengage.
Try putting the car in reverse and forward back and forth..Give just a little acceleration,,while doing this..Sometimes this will let it break free
Oct 10, 2011 | 2001 Ford Taurus
1991 Crown Vic dies in reverse and park
SOUND LIKE THE LOCK UP IN TORQUE CONVERTER IS BAD BUT IT IS IN TRANSMISSION YOUR PROMBLEM
Aug 19, 2009 | 1994 Ford Taurus
Craftsman 24 Hp 48" Deck Yard Tractor Logo
208 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
