Question about Turbo Air 49 cu. ft. / 1388 liter Upright Freezer TSF-49
Is the Tubo Air TSF-49 a manual defrost and if so; can it be converted to auto defrost control?
  • Turbo Air Master
  • 1,144 Answers
It is automatic. If it is not going into the defrost mode, the defrost timer may not be working.
Posted on May 17, 2010
My turbo air freezer iced in coil i unplug over night and i plug back and work normal about 3 to 4 day and then iced in coil again
Defrost element has had it or timer will not shut unit off, check both, if both ok, check thermo fuse.
Need any more help, email me at russ_sheraton@hotmail.com or call me 08 9523 0552 West Australia.
DONT FORGET TO VOTE, I JUST SUPPLIED MY TIME FOR FREE. Hope you get it sorted. Regards Russ
Mar 02, 2011 | Turbo Air 49 cu. ft. / 1388 liter...
Unit is off and will not come back have checked power source and it is ok.
does the compressor make any noise at all? If not, there is a control problem. If it does make noise I need further info and details. Let me know.
Jan 19, 2011 | Turbo Air 49 cu. ft. / 1388 liter...
If we set the freezer to cut off at -10 next day it might cut off at -32 or it might just continue to run the compressor
definately sounds like a control problem. I'd start in that area first. Let me know what I can do for you. Just be sure to include the model and serial numbers and we will give it our best shot.
Jan 15, 2011 | Turbo Air 49 cu. ft. / 1388 liter...
Looking at new freezer, what is the difference between Turbo air TSF-23sdr and TSF-23nm? product specs would not download. thks
Do you mean the MSF-23NM and the TSF-23SD? If so, you can find the information for them here:
http://www.turboairinc.com/TB-Products/Soliddoor.html
Basically, the difference between the two is that the MSF-23NM runs on more amps and is a new "maximum" series that Turbo Air came out with.
http://www.missionrs.com/MSF-23NM.html
http://www.missionrs.com/TSF-23SD.html
The product spec sheets at the two links above should be easy to download from our site. If you have any trouble, you can call us at 1(800)319-0690.
Sep 22, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Msf-49nm freezer will not go below 34 degrees farenhight
Change the temp control,check to see if it is iced up on the evaporator
Sep 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Defrost times and adjust
http://www.turboairinc.com/TB-Service/Service%20Manual%20%20-%20April%202008/TSF-49SD.pdf
go to this site and check out the service manual. I guessed at the unit you had as you did not include the model number.
You can also go to turboairinc.com and search for more info if you need to.
Hope this gets you your answer.
Apr 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
I have an electrical burn smell inside the 49sd, all seems to be working... just the smell that is stronger inside.
This is the web site for your manual for your unit. I've had some situations where some rubber type insulation has melted but I've not experienced any problem other than it makes a mess. Hope this helps.
Feb 26, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Looking for the white plastic clips that shelf hangs on.
Give Rick a call at Restaurant Parts and More. Turbo Air also makes Master-Bilt. Rick can probably get what you need. Just have the model and serial. He's good at this stuff. 1-888-814-1110.
Mar 21, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Maytag side by side refrigerator
fridge has timer to adjust for defrosting, but the not working working you to manual defrost the unit to avoid ice formation inside the fridge.
Dec 30, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Freezers Logo
184 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
marlin siecinski
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
