Question about Starrett T216XRL-1 - MICROMETER, DIGITAL
Spindle movement jammed - Starrett T216XRL-1 - MICROMETER, DIGITAL
  • Mahesh Makwana
    Mahesh Makwana Jan 17, 2016
    Don't DEEP BECAUSE it's Digital micrometer
To clean jam of micrometer use good quality Rustfree spary like WD- 40 spray
Spray it or deep it in a tray for 24 hours then gradually
Open
Posted on Jan 17, 2016
  • Mahesh Makwana
    Don't deep Digital micrometer in tray only spray after opening micrometer &take out battery cell
    President:
  • 2,030 Answers
It has something stuck in it...do not try to force it
send it to an authorized Starret repair facility to be repaired
Posted on May 16, 2010
My wiper motor seems to have a siezed spindle. With it disconnected from the wiper and just on its own I can hear the motor running but no movement from the spindle is noted.
then the wiper arm transmission is what is damaged not the motor
not lubricated properly is a main cause
if the spindles wont tighten up it is worn out
this wiper assembly should be replaced as a new unit
..used parts are not as reliable
start watching @5:30 then again @ 7:10
under the turtle cover might be the problem
how to remove Mercedes w202 windshield wiper motor assembly and lube
Aug 06, 2016 | 1998 Mercedes-Benz C-Class
One side of mower wont turn
Your spindle may be seized. try turning the side by hand. Try moving it back and forth. If there is movement then your bearing in your spindle is bad. I f no movement than check under your deck to make sure nothing is stuck holding the blade from turning. You will probably have to replace your belt as well
Aug 06, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
There is a wom wom sound and vibration coming from my 03 Trailblazer. I believe it's the wheel bearings. Are they easy to change myself?
yes, it is possible that the spindle bearings are bad. this is a sealed unit!!! have to buy whole spindle. easy to install by experienced mech.
just jack up each side and grab tire top and bottom and try to move back and forth!! any movement is bad!!! just look good and make sure the movement is coming from the spindle area and not the ball joints!!! hope nthis helps!!!
Nov 29, 2013 | Cars & Trucks
Chuck will only turn side to side after repair of gears box after
I need more information to answer your problem.
The chuck normally has movement turning because of the clutch gear.
It is possible if you had a gear strip or spindle break that there are pieces of metal in the grease that have jammed your new gears. I would recommend tearing down completely, remove all the grease, thoroughly clean gearcase, regrease & reassemble.
Nov 13, 2013 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Makes noise will not spin
Possible that the motor is slipping . This can be due to JAMMED spindle or shaft of the agitator. it can also be due to faulty belt, drive or fault in the motor. Manually check the free movement of the motor to confirm this or reset the assembly to free the movement,
Jan 17, 2013 | Washing Machines
Kenmore 110-27831600
Possible that there is no free movement of the spindle and drive. You must check for the free movement manually with you hand- switch off power when doing so.
If the spindle is tight then the assembly must be removed and reset.
Check the action of the brakes, if this holding on you can remove to test and then reset. check the motor movement.
Jan 17, 2013 | Kenmore Washing Machines
Kenmore 11023032102 washer
Possible that the belt has worn off or the spindle is struck. Try and manually turn the pulley and see if there is free movement, if not the assembly must be removed and reset.
check this link: Spindle bearings
Oct 08, 2012 | Sears Parts Direct Agitator - 8578210
How do I tighten chain on 2004 daytona triumph 600
Good Afternoon. To Adjust the chain:
1. Position the bike on its stand, or up on paddock stands if you have them.
2. Loosen the rear wheel spindle nut (see diagram below)
3. Slacken the adjuster locknuts on each side of the swinging arm
4. Moving both adjusters by an equal amount, turn the adjuster bolts clockwise to increase chain free-movement and anit-clokcwise to reduce chain free-movement.
Important - Ensure that the wheel spoindle blocks on both sides of the bike reamin in contact with the adjusters through this process.
5. When the correct amount of chaiin free-movement has been set, push the wheel into form contact with the adjuster. Tighten both adjuster locknuts, and the rear wheel spindle.
Apr 17, 2011 | 2004 Triumph Daytona 600
The motor on the Bamix hand mixer is working properly yet the spindle will not spin. It appears as if it is not engaging. The spindle is not jammed.
there is a rubber connetion between the motor spline and the spindle which holds the screw that connects to the spindle, this has broken
Jun 09, 2009 | Bamix Immersion Handheld Blender
Dewalt 708 sliding compound mitre saw
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Oct 07, 2008 | Saws
Starrett T216XRL-1 - MICROMETER, DIGITAL Logo
402 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
Vernon Taylor
ray gallant
Vuk B
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
