I have a Toshiba 62HM95 LCD Rear projection TV and every time I turn it on now, it makes a loud buzzing/humming noise. Just started a week ago. Help!
  • franke_rodri May 17, 2010
    Just want to make sure the original assessment is correct before i go out and purchase a voltmeter and ohhmeter.
  • 10,594 Answers
Only two components can make that kind of sound in this tv, exhaust fan or color wheel and visual check will confirm noisy exhaust fan but color wheel is part of light engine so qualified tech would be fine to handle that issue as novice will make problem more complicated.
Hope these info will help you.
Thanks.
Posted on May 17, 2010
    how do i visually check the exhaust fan?
  • Shahid Electronics
    Shahid Electronics May 17, 2010
    Take off back of tv and confirm that exhaust fan is producing noise.
  • 11,896 Answers
Sounds like one of your capacitors or power inverter may be soon to go. Testing capacitors can be done with an ohmmeter or analog meter. Testing the power supply aka power inverter can be done with a voltmeter. There should be a label on the tv that states the DC Voltage Output. Make sure the reading of the voltmeter are the same or close to the same.
Posted on May 16, 2010
  • 1 more comment
    okay....so? First I have to get the tools -- an ohmmeter to test the capacitor and then a voltmeter to test the power inverter -- and then see if the volts from my power inverter match the posted DC Voltage Output? Let's assume I'm able to do all that, but the voltage doesn't match? then what?
  • Nate Stansfield
    Nate Stansfield May 17, 2010
    If voltage doesn't match, then the power inverter will need to be replaced.
  • Nate Stansfield
    That is my theory. If you feel like getting an analog meter / ohmmeter and voltmeter, you can use them for many things. Very useful life-long tools.
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Loud clicking noise from the rear of tv and the light keeps going fromred to green
is it a rear projection tv? could be the bulb or if its the noise mine made look at getting a new tv. load noise when u turn it on and then stops after a min or 5 if it stays on. time for new tv. circuit board! can get a new tv for the price of trying to fix it
Mar 17, 2013 | Toshiba 62HM95 62" HDTV
Will the lamp still light if the color wheel does not work
Your set does not have a Color wheel , Your color is Projected thru Light Engine.
Dec 31, 2009 | Toshiba 62HM95 62" HDTV
Humming noise
The light enigine shouldn't be that difficult to replace if you have a decent amount of time and are moderately mechanically inclined. You can order the original Toshiba replacement light engine for this model (62HM95) from a major Toshiba parts distributor at the link below:
Toshiba 62HM95 Replacement Part Light Engine / Optical Block
Apr 01, 2009 | Toshiba 62HM95 62" HDTV
Humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
Aug 09, 2008 | Toshiba 62HM95 62" HDTV
Humming/buzzing sound
That could be either the ballast, or colorwheel. Does the sound get louder at the rear of the tv or louder in front. let me know I may be able to help you.
Apr 08, 2008 | Toshiba 46HM95 46" HDTV
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
Loud buzzing noise
Yes,it sounds like the color wheel motor is going,and yes it satais on untill lamp cools down
Oct 13, 2007 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
