Wont load windows only says f11 to run operating systems or control alt. delete to restart do i need a recovery disk
  • 813 Answers
Hi frined
ur hard disk has been need to recover or its has been dmaged or its have a bed cristels in ur hard disk that y this earror come
which compny u have hard disk
then downlod the dm(disk managemet) software to recover ur hard drive
Posted on Mar 31, 2008
SOURCE:
Hp site
Use Recovery Console
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
OR
Use Last known Good Configuration:
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
Jan 01, 2012 | HP Computers & Internet
The cursor is frozen in the middle of the screen. I have tried FN + F5, FN + F9 nothing happened?
try control F11. If that does not work, press the windows button (if equipped) on your keyboard - and use the arrow keys to scroll over to restart the computer.
If this does not work, press and hold, control alt delete until the computer restarts. This is not a recommended practice, but is an alternative for a situation like this. It will not harm your computer; if this does not work (the first option should) then simply push the power button on your tower; this is a last resort option - restart the computer - you will see a menu appear - select "start windows normally". Once the O.S. has loaded, your mouse should be reinstated.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 27, 2011 | Computers & Internet
How do I install a windows recovery disk?
Hello and welcome to FixYa.Com
To install a Windows XP recovery disk go to the follow link and download it directly from Microsoft:
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8
I hope this helps, and dont forget to vote!
Feb 28, 2011 | Microsoft Windows XP Professional for PC
Laptop cannot run windows ,keeps trying to run but keeps returning to start windows or goto safe mode or start from most recent workable point. says some file missing or corupt and cannot load hive file?
This means that your laptop operating system is corrupt you will need to restore it using the recovery console on your laptop. You should be able to access this by pressing the F11 key when you power on your laptop from the post screen. Some laptops use the ALT and F10 together ie. acer and packard bell. But most use F11. If you laptop will not recover using the recovery console you will need to replace your HDD (Hard Disk Drive).
Hope this helps if you need more help just ask.
Feb 22, 2011 | Computers & Internet
Press f11 to start recovery doesn't work
do you have a recovery cd or a copy of windows xp, try pressing f12 to get to a boot menu or f8, to get to a safe boot option or a last previes known good option, or some thing like this. press these options on off on off just before it goes to load the windows. try that hope it helps
Nov 30, 2009 | Cameras
NTLDR is missing..how can i log-in to the windows?huhu..pls help
NTLDR is missing Press Ctrl+Alt+Del to Restart hmm..there's still no effect even if i press Ctrl+Alt+Delete..what should i do?
Aug 28, 2009 | ASUS Eee PC 1000H Laptop
WINDOWS VISTA HOME PREMIUM WONT BOOT UP
Dear Sir,
If your recovery discs don't function then have you got a recovery partition...If you do have it then as soon as you restart the system press the F11 key on the keyboard...The first option click next then click no then next then yes for system recovery then next and follow the instructions...If F11 does not work then you will have to order a new set of recovery discs from the company and if the same problem occurs then send in your system for repairs
Aug 16, 2009 | Computers & Internet
How to restore my acer aspire 5001 to factory settings i tried the normal restore but it dont work can you help pls ,,cheers neil
Hi I contacted Acer about this myself and this is what they wrote back.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jul 09, 2009 | Acer Aspire 5100 Notebook
Compac deskpro Pentium 111 - 600
I'm not completely sure on what you are exactly asking here, but I'll do the best I can. If you have the Recovery CD, you need to boot from the CD and run the Recovery. When you go to do the recovery you will have two options, the normal recovery or the destructive recovery. If there is nothing important and everything can be wiped, run a destructive, but if you need everything run the other one. If you do not have a Recovery CD but have a Windows Vista disk that matches the version on your computer (IE: Windows Vista Home 32 bit is on your computer and you have a Windows Vista Home 32 bit disk) and you DO NOT need anything saved, just reinstall Windows. There is a product key for Vista on the sticker attached to your case. If you have neither, then you can probably get a new recovery disk by contacting HP (since they bought out Compaq). If you can not get a new Recovery CD, you will need to go out and buy a new copy of Windows Vista.
Feb 20, 2008 | Compaq Deskpro EN PC Desktop
Open Questions:
AOL EMAIL TECHNICAL SUPPORT 18OO8O31O69 CONTACT NUMBER There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
Oct 22, 2019 | AOL Computers & Internet
Computers & Internet Logo
52 people viewed this question
Ekse
Marvin
Marvin
