Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Starts but cuts off when given gas
This is a power mac 6 mdel 600086u serial 1362353
    Brigadier General:
  • 4,088 Answers
Check the muffler and air cleaner for plugging. Make sure the carburetor is tight to the engine. Turn the H jet needle CW to stop (lightly), then back out CCW 1-1/2 turns. Start the engine allow to warm up. Pull the throttle full on and adjust H CW until the engine speeds up somewhat, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Hope this helps!
Posted on May 16, 2010
Testimonial: "working fine now thanks !!!!!!"
  • marcmharris Mar 28, 2011
    any chance of getting a copy of that manual? i inherited it recently and need to repair it
Why does it Start and idle great but when i aply gas injectors close
You very likely have clogged injectors from dried up fuel.
Apr 26, 2016 | Cars & Trucks
Tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing...
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Step 2. Choose Apple ProRes for Final Cut Pro.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Need to know the Internal Hard drive cable serial no to purchase.
1. Click on the apple logo ?
2. About this Mac
3. System Report
4. Scroll through the given information, I guess you're looking for the storage information.
Jan 05, 2016 | Computers & Internet
I have a devilbiss generator mdel #gb5005 runs great but no power output any ideas
If the unit has been setting for a long time you would need to start with re-exciting the field.
If this does not resolve the problem the first check the winding for short to grounds, also check the resistance readings.
If these are all ok and within specs... then you will need to check the diode.
You can find a service manual at www.msservice.net
Oct 14, 2014 | DeVilbiss 7000 Watt Generator
I lost my final cut pro 4.5 hd serial key i want
Should be on the box or among the papers with the software. If you can't find this try contact Apple...
Sep 07, 2013 | Apple Final Cut Pro HD 4.5 for Mac
I need a sebelius 6 serial number urgent
Did you buy this software? You should have the serial number already unless you lost it.
Goto, A232 Serial number - how to determine your serial number
232: Serial number - how to determine your serial number In Sibelius 3 and later, your serial number appears at the bottom of the Help > About Sibelius dialog (in the Sibelius menu on Mac OS X).
Your Sibelius serial number is also printed on the back of the case that your original Sibelius CD-ROM came in. Don't lose this CD-ROM case, as without your serial number you will have problems reinstalling or re-registering Sibelius.
If you have lost your CD-ROM case and your serial number, contact technical support in writing and ask for their assistance. In the interests of security, you may be asked for proof of purchase and identity before you can be given your serial number.
or
A206 Registering Sibelius
For instructions on how to register Sibelius, see Registering Sibelius in your Sibelius Handbook or Installing,...
May 31, 2011 | Computers & Internet
I have a sentry safe that was given to me by my grandmother. It is so old that it only has the serial number on it. I have the combination but the safe will not open. HELP!
Do you need to re-use the safe? If not, it takes 5min (ok, maybe 10min) work with a Milwaukee grinder (thin metal cutting 6" disc)
Apr 20, 2009 | Sentry Fireproof Safe
Older ArtZ II with ADB cable won't talk to my laptop
I'm thinking this is a Mac-only tablet. The ArtZ II for Windows came with an rs232 (old mouse) port at the end of the cable, in addition to a built-in spot where the power plug attaches.You didn't mention the power plug on yours, so the Mac version of the tablet must have the power routed in through the cable.
Short answer, the reason the light isn't coming on is because the tablet isn't receiving power. If you go get a cross-platform adapter card for plugging in Mac hardware on your HP, it *might* work.
Nov 25, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
262 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
