Question about Uniden BC350C Base Scanner
How do i clear all chanels on bear cat 350c scanner
    Genius:
  • 1,274 Answers
Program 000.0000 into the channel, then press PRO...CH. UP or DOWN.....hope this was helpful....
Posted on May 16, 2010
  • nc4jeff Dec 12, 2010
    also you can hold down L/O and Prog while you turn it on.
    Hope this helps
Hi. how can i delete all my channels and then put in new channels
You can clear all the stored information by resetting the scanner. While holding the 2, 9, and Hold, turn the scanner on. In about three seconds the display will show "CLEAr".
If you need a manual you may download a copy here.
Aug 04, 2012 | Uniden Bearcat BC92XLT Handheld Radio...
Hi i'm claude i just purchase the uniden bc72xlt scanner and all i get is a police chanel accessed mabe once or twice in an hour.i also had to resset the scanner the first time because i was making...
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Jan 10, 2011 | Uniden BC72XLT Handheld Scanner
Hi I just purchased auniden bc340crs and am having problem to program it I press the pgm key to find the chanel I want to put the frequency I want but the chanel stay on the waether chanel how can I get...
Make sure that the slide switch marked MODE is in the far right (Scanner) position before you start programming. If you need the manual for your scanner, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
Bill B.
Jan 03, 2011 | Uniden BC340CRS Base Scanner
How can i program a higher frequency on this scanner
Top end on the 350C is 956MHz, and it won't go any higher, no matter what you do. You may know it already, but the 350C is not capable of "standard" keyboard programming - direct entry of a frequency via the keyboard. Rather, you must locate an active frequency using the SEARCH or SCAN mode, and then transfer it into the PRIVATE bank (bank 7). Detailed instructions for doing this are found in the owners manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC350Com.pdf
Bill B.
Dec 05, 2010 | Uniden BC350C Base Scanner
Looking for a manual for a uniden bearcat 30 chanel scanner
Uniden scanner manuals can be found at the following location:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Just click on the model of your scanner and download it.
Hope this helps!
Jan 03, 2010 | Uniden BC248CLT Base Scanner
The private channels on my bc 350c uniden scanner are locked. how doi unlock them?
Here's your manual. Page 31 explains how to unlock a programmed channel, hope this helps.
Sep 27, 2009 | Uniden BC350C Base Scanner
Repair bear cat 101 police scanner
first of all check the antenna connection, it could be dirty which causes more impedance at the higher frequencies than at the lower ones (uhf is higher than vhf), also hum could come from a power supply that can't produce enough current, does it get worse when you turn the volume up high? if so and you use a wall adapter, you might need one that has the same polarity and voltage but a higher current output, such as 400ma compared to 250 ma. If the power comes from a standard ac cord without the transformer (cube) at the wall outlet, then the internal supply might need a new capacitor in the filter circuit.
Jan 14, 2009 | Radio Communications
Uniden BC350C Base Scanner Logo
243 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
