I have a Mitsubishi VS-50805 HD 1080 Series Projection TV. I found 1 fuse and tested it and it is good. When I plug the set in I hear a VHUMPP sound but only when its been unplugged for an hour or so.
  • guyleatherma May 16, 2010
    I tested the fuse with my multi meter. It was 0 ohms. I consider that good. I also tested 5 of the green pico fuses on board. Three of them are 0 ohms (i.e. good), and two of them are bad (infinite ohms). Do I need to replace the two pico fuses? If so, whats the easiest way?
    President:
  • 3,130 Answers
You cannot tell if a fuse is good by looking at it you need to check it for full contunuity with a meter
Techman
Posted on May 16, 2010
Cannot get my compoent cables to show on the tv mitsubishi hd 1080 series model vs-A50
Assuming the cables are good etc. this set has 3 hidden menus, one is the OPTION menu which will reset almost all settings back to default.
I have seen it cure no sound, no video, all sorts of odd things--it will not affect convergence which is stored in another area but a missing or non working input it may cure.
I have the 4 number code for doing this but you have to have a working original Mitsubishi remote--universal will not work.
Let me know if you want to try it and I will provide the code and general instructions for doing it.
Dec 21, 2012 | Mitsubishi VS-50607 50" Rear Projection...
check the convergence ic's unplug the main convergence board plug then try the set again if the set comes on get a convergence kit here
http://www.tvrepairkits.com/xcart/home.php?partner=larry
May 16, 2010 | Televison & Video
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
I have a mitsubishi model vs-50805 projection tv and my picture has a 3d effect u can see the letters in the menu in 3 colors
the problem with this unit is in the convergence ic's need to replace and check for bad resistors and pico fuses in the circuit
Jan 25, 2010 | Mitsubishi VS-50805 50" Rear Projection...
I just wanted to know how much they go for. Mitsubishi big screen tv hd 1080 series model vs-60111
Probably 1500.00 new, but that's an old set. If your trying to sell it I would ask 350.00 for it, if it works.
Dec 18, 2009 | Mitsubishi VS-60111 60" Rear Projection...
I own a Mitsubishi HD 1080 series HD TV; MODEL#VS-50111. Recently the TV shut itself off after a few minutes of operation. I unplugged it and after a few hours, plugged it in and it came on for about 5...
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Oct 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Flashing Tv screen
Turned out to be a problem with my dish receiver. Found out by attaching a separate DVD unit to the TV, and it didn't flash. I then realized everything ran through the dish receiver. Called them, reset ( by unplugging for 90 seconds) and all was well.
Jul 20, 2008 | Mitsubishi VS-60111 60" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
