Question about Grilling
My regulator on my gas grill leaks propane out what looks to be a blow out vaulve is there any way to reset it so it doesn't leak?
  • Grilling Master
  • 3,248 Answers
I would change it could have a spilt diaphram causeing gas to leak out
Posted on May 16, 2010
Full tank but no gas smell and just bought a new hose and regulator
follow this steps and fix it. God bless you
Test the propane tank valve for leaks:
  1. Turn the grill control knobs on the front (and, on some models, the side) of the barbecue to the off position.
  2. Turn the propane tank valve fully counterclockwise to close it.
  3. Mix a test solution of equal parts of dishwashing liquid and water in a small container.
  4. To test for leaks, apply the test solution liberally to the connection between the regulator fitting and the tank valve using a small paint brush. Apply the test solution to the valve handle and threads, the length of the hose, and the connection between the hose and the regulator. If bubbles appear at any point, there is a gas leak.
  5. Tighten the connections and retest.
  6. If you still see bubbles at any of the tested connections, close the tank valve and replace the leaking component.
Test the hose fittings for leaks:
  1. With the tank valve open, brush the test solution on the fitting at the other end of the hose, located under the control knobs.
  2. Turn the control knob to high and test the hose and fittings leading from the control knob to the grill. Turn the right control knob to off. Repeat the process for the other control knobs.
  3. If you see any bubbles during any of these tests, close the tank valve and contact your propane dealer or your local gas utility. Do not use the barbecue until the leak is corrected
Oct 29, 2013 | Weber Genesis Silver A Grill
Changed tanks like I always do went to lite heard this propane blast then it lite but doesnt regulate like before.
what does that mean? doesn't regulate like before? it is common to trip the check valve with a new tank because the over-fill prevention device float displaced the liquid in the cylinder which causes vaporized propane to hit the check valve too hard. the tank thinks it is leaking and shuits down gas flow so it is difficult or impossible to cook. reset the check valve by turning everything off. disconnect tank at regulator. turn grill valves on high, all of them. count to 100. turn the valves completely off. re attach the cylinder at the regulator. turn tank valve to turn on but very, very slow for the first full 360 degrees so the gas can only seep-through slowly. we do not want the gas to rush out and hit the check valve too hard.
Oct 23, 2013 | Barbeques Galore Turbo Classic 3-Burner...
Trying to address a leak on my Weber Genesis Silver B Grill, I replaced the hose/regulator. Unfortunately, I still hear gas flowing and smell gas if I do not turn off the propane tank valve completely. ...
Mix some water and detergent together - where ever it bubbles that is where the leak is. Sometimes the thread is worn so get some GAS Tape and undo the thread - wrap tape around re-tighten and then check for leaks again with soapy water
Apr 12, 2011 | Weber Genesis Silver B Grill
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
New Charbroil gas regulator leaks
The connector on the grill side that connects to tank may be bad. Call manufacturer and they should send you a new hose and regulator for free since it is a new grill. If grill does the same then replace tank.
Apr 25, 2010 | Char-Broil CharBroil Master Flame Gas...
I have a gas grill and fire shoots out the temp.
You have a gas leak. DON"T use it untill someone qualified looks at it. A small 20# propane tank can blow a hole in a wall, so you can imagine what it would do to you.
Apr 20, 2010 | Char-Broil Charcoal Water Smoker 4654301
I have an older Genesis grill with a leaking regulator
You can get a replacement regulator at just about any home improvement store (Home Depot, Lowe's, etc.) There haven't been changes in the size of the ports or thread patterns on regulators or propane tanks in the last 15 years.
Oct 07, 2009 | Thermos Stainless Steel Gas Grill
Second and third burner burns with a low flame. Burner closest to gas supply works as usual.
This problem can be caused by a number of things. Is this a new grill? If not, is this a new problem?
First -Check to see if the fuel hose is bent or kinked.
• Make sure the grill area is clear of dust.
• Make sure the burner and orifice are clean.
• Check for spiders and insects.
• The regulator has a safety device that restricts the flow of gas in the event of a leak. This safety device can be triggered without a gas leak. To reset the safety device, turn all burners "OFF" and close the Liquid Propane cylinder valve. Disconnect the regulator from the Liquid Propane cylinder and wait 1 minute. Reconnect the regulator to the Liquid Propane cylinder and slowly open the valve until the valve is fully open. Light all burners and observe the temperature.
Sep 04, 2009 | Vermont Casting Signature VCS3507N ...
My grill does not come up to the proper temperature. There is nothing that seems to restrict the gas flow. There is a sputter sounds so I think the gas feed is restricted. Can you help or suggest what may...
Sep 03, 2009 | Weber Grilling
My kenmore elite gas grill will light, then quickly go out.
check for leak if it is propane if no leak most likely regulator and hose
Aug 10, 2009 | Grilling
Grilling Logo
255 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
