Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Too dark and the red and green color too much..
    President:
  • 1,099 Answers
first to check waveforms going into the vertical output stage. The supply voltage is probably correct since that often determines the size. It almost sounds like the waveform rather than being mostly on (active video) and off for the short blanking period is somehow only on during the last part of the active video thus giving you just the bottom of the picture. If there is a vertical output IC, it may be defective or the blanking input to it may be corrupted. The problem may be as far back as the sync separator. Then again who knows, maybe wait for the schematics. CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
Since you have high voltage, the horizontal deflection circuits are almost certainly working (unless there is a separate high voltage power supply - almost unheard of in modern TVs and very uncommon in all but the most expensive monitors).
Check for bad solder connections between the main board and the deflection yoke. Could also be a bad horizontal coil in the yoke, linearity coil, etc. There is not that much to go bad based on these symptoms assuming the high voltage and the horizontal deflection use the same flyback. It is almost certainly not an IC or transistor that is bad.
Posted on May 16, 2010
Whats the color codes for a 2001 dodge ram 1500 stereo wiring harness?
2001 Dodge Ram 1500 Radio Wire Colors
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Mar 30, 2016 | Dodge Cars & Trucks
The grey in my relaxed brown hair occasionally turns a greenish color I use adore semi permanent, dark chocolate any idea how to avoid this?
Your hair is turning green because your missing red when you color your hair. Gray is uncolored hair and to get to a dark chocolate brown you need to add a little red to the color to make up for this. You don't need to strip it out.
Have you heard of people using purple shampoo to neutralize the yellow tones of their blonde? Red will neutralize the green tones, so adding a little red to your color will do this for you.
Mar 09, 2014 | Adore LVT Semi Permanent Hair Color 112...
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Dec 25, 2010 | JVC Car Audio & Video
Rewiring 1968 cutlass I need color codes
The wire color code is as follows:
BLK= Black
BRN= Brown
RED= Red
ORG= Orange
YEL= Yellow
GRN= Green
BLU= Blue
GRY= Grey
WHT= White
PPL= Purple
PNK= Pink
TAN= Tan
LT BLU= Light Blue
DK BLU= Dark Blue
LT GRN= Light Green
DK GRN= Dark Green
Let me know if you require any further assistance.
Oct 20, 2010 | Oldsmobile Cutlass Cars & Trucks
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
Wiring diagram for 1999 dodge durango
1999 DODGE DURANGO
4DR SUV
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery RED/BLUE (+) RADIO HARNESS
Accesory RED/WHITE (+) RADIO HARNESS
Ground N/A
Illumination BLACK/YELLOW (+) RADIO HARNESS
Dimmer ORANGE (+) RADIO HARNESS
Amp Turn On DARK GREEN/RED (+) RADIO HARNESS
LF Speaker (+) DARK GREEN
LF Speaker (-) BROWN/RED
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BROWN/LIGHT BLUE
LR Speaker (+) WHITE
LR Speaker (-) DARK BLUE/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BROWN/ORANGE
Amp Location PASS KICK PANEL
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
May 10, 2009 | Audio Players & Recorders
Match color of my bike
1999 GL1500SE
Candy Spectra Red, R176C. Inset panel colour is Candy Garnet Red, R199C
Pearl Glacier White, NH326M. Inset panel colour is Glacier White Accent Gray, no code available
Pearl Twilight Silver, NH390M. Inset panel colour is Dark Silver, no code available
Pearl Mercedes Green, G167. Inset panel colour is Dark Green, no code available
Gloss Black, NH1Z
Mar 29, 2009 | 1999 Honda GL 1500 SE Gold Wing
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
109 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
