Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
I HAVE A 50V500 HITACHI PROJ. TV . EVERY THING HAS A GREEN TINT.
I STILL CAN SEE FLESH TONES AND OTHER BUT THE GREEN OVER SHADOWS AND DOSE NOT LIT THE BRIGHTNESS THROUGH, PLEASE HELP,THANKS BUBBA
  • 2 more comments
  • bubbadent May 16, 2010
    I TOOK OFF THE FRONT FO THE TV AND FOUND NO ADJ. IT IS A 50V500A ULTRAVISION HITACHI LED PROJ. TV
    THANK YOU GINKO BUT I CAN GET NO HELP FORM HITACHI
  • bubbadent May 17, 2010
    why dont anybody ansewer back
    THANK YOU FOR ALLLLLL YOUR HELP
  • 4,889 Answers
I am so sorry to tell you that you have an optical block related problem. All the symptoms you have described match the description of an optical block failure. Replacement block nearly costs as much as a new tv. Is the tv under warranty? There have been several class action lawsuits against companies producing faulty rear projector failures and nearly all of them here in India have been decided in favor of customers. Worth a try if the tv is less than 5 years old.
Posted on May 17, 2010
    President:
  • 3,130 Answers
Bubba are all three red green and bulbs lit up or does the picture look like a 3-D picture??
Techman
Posted on May 16, 2010
    I ONLY KNOW OF 1 BULB IN THIS TV LAMP#UX21511
    SORRY:NO IT DOSE NOT LOOK LIKE 3-D. THE PICTURE JUST HAS A GREEN TINT AND DARKER THAN IT SHOULD BE. OTHER THAN THAT ITS GOT A GOOD PICTURE. BUB.
  • Hitachi Master
  • 19,396 Answers
Hi Bubba.
You can try doing a reset from service menu. There is also an LCD adjustment on service menu that can often fix the problem.
First check that the problem does not depend on a faulty connected device (eg. a receiver) or on a bad cable. Also try resetting the set by disconnecting power cord for about ten minutes.
To enter the service menu:
  1. Select an input with no cable or device connected (eg. Ant B, Vid2).
  2. Turn off the set and wait until the fan turns off.
  3. Hold down input and power buttons at the same time.
  4. The servicemenu should appear on display, release input button first, then power button.
  5. Use the remote to browse service menu, and select reset.
  6. Press exit button on remote twice to exit service menu.
  7. Chance source back to regular input.
If that does not work, there may be a fault, concerning LCD, terminal circuits (input), light engine, or video circuits. The lamp does not cause green hue.
If you want a quote on repair, call Hitachi at the phone number listed on the owners manual.
Here all parts for this set.
Regards.
Ginko.
    how do I get too the led adj?
  • Ginko
    Ginko May 16, 2010
    There are no adjusment knobs on this TV. This is not a Sony CRT, it is an Hitachi rear projection LCD.
    As said settings and adjusment is done from service menu, operating remote to select LCD Adjust or reset. If that does not work, then faults that can cause green hue may be related to input, video section, light engine, or LCD panel.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First check whether all the cables from your dish net work are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. So we are doing real small adjustments. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture. And, if it doesn't resolve the issue then it is an intermittent blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue CRT board, or a problem in the RGB coming from the video jungle IC. Please replace whichever has gone bad. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    i took the front off and found no adj. It is a 50v500a ultraviision
    RYLEE YOU STILL THERE?
The TV works fine but the screen is green. Color
R G B circuit transistor to be checked. This is located in the picture
tube connecting end PCB. ( Neck ) Check the transistor and its components.
Can be dry solder also!!
Jul 28, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
The screen has a reddish tint to it. Seems like a color issue and not sure what to replace. The picture works fine but everyone is red. Not sure if there is a bulb to replace or what? Any suggestions? This...
You need a simple color adjustment. (Color Calibration)
You don't need to spend money on this. Try it for yourself.
Your main problem is that your color temperature is set to warm.
You need to change temperature to COOL or 6500K depending, on how it is labeled.
You will see improvement, but there is a little more...
Move "Color" DOWN from it's current position (probably at 50) to somewhere between 30 and 40. (Just a couple of clicks above where the color rapidly washes out.)
At this point there will still be slightly unnatural color to skin tones, but all the artificial "sunburn" and blaring red will be gone.
Last (as far as color goes) move the tint 2 to 4 clicks toward green. This added green tint balances the color so that the flesh tones become completely accurate and realistic.
For even better detail, continue your home calibration here:
http://www.wowvision.tv/main.htm
Jun 13, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Ghosts or shadows around images
I always start my Hitachi research at their website.........
www.HitachiServiceUSA.com...................T.
Nov 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 tv blue shadows
If it's a ghosting problem that looks like this:
it's probably something you can correct yourself...
Nov 21, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue tint on corner of tv hitachi 50v500
simply tease the blue transition patch with a positive charged magnet
Oct 15, 2007 | Hitachi UX21511 Projector Lamp for 50V500
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
236 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
