Question about RCA P52771AT 52" Rear Projection Television
TV has no power
Tv has had a problem with turning off and then back on. After a while it breaks and hass no power. I have had the high voltage dividr replace twice this year. It mad a loud pop when I turned it off and now has no power again
    President:
  • 3,130 Answers
Try disconnecting the red wire from the hv distribution block right behund the front speaker grill then take off the wood cover it looks like a distributor cap with a bunch of large red wires connected to it the wires run to the picture tubes, and one goes to the flyback tranformer on the pc board.the high voltage is black or grey in color
Techman
Posted on May 16, 2010
Power-On Problem on a 46" Sceptre Flat Panel
The high voltage spike damaged electronic components inside your tv. Transistors and microchips are very sensitive to high voltage spikes even if they last for a fraction of a second. It can probably be repaired by a tv repair person but if the tv is several years old, it would be better to just buy a new tv. The cost for a new tv is much lower now than it was just a few years ago.
Feb 13, 2014 | Sceptre Televison & Video
Hi, I have a JVC 32inch Model# AV32050 and at first it took several attempts to get it to power on, but now it will not power on at all.I hear a high pitched sound while it is plugged in outlet. A few...
Take the tv aparts.Take out the tv video board that is connect to the CRT tv tube.Plug the tv back in "High Voltages" be very careful now.Find wire with solid insulaition grounded in a metal frame some where the other end of the wire go toward the "High Voltages" Open CRT tv tube,u will hear a big "POP".Now unplug the tv.Put the tv back together again,nor tv CRT tube should be clean out of bad contamination poison.The tv Focus well be clear up and work as normal tv again.If u scare don't want to mess around with open "High Voltges" pay the tv shop like $50 bucks they can do this job for like 20 mins.
Jun 06, 2011 | JVC AV-32050 32" TV
Screen does not switch on at all , and no sound either. However standby light is on only when plugged. TV repair told me it is transformer and line up, however asking for more then 100...
Hello, most common faults, such as CRT TV will not turn on. The reason stems from the low power supply failure, or from the high power supply. There are two transformers suppliers, with more common high-tension transformer goes bad. Price of 80 or $ 100, sounds reasonable replacement of transformer. Along with this need to perform some tests that require a professional, to confirm that the problem is due because of transformer. One test is to test basic stability, voltage power reaching the high-voltage transformer. If lower than normal voltage. Then perform the same test, when you break the initial snap of the transformer. If the voltage rises to the desired level must be to replace the high voltage transformer. Good luck!
May 12, 2011 | Sanyo Televison & Video
When turn tv on it blows fuse on the power supply board
It means you have a power supply problem or high voltage issues. RCA sets are well known to take out a number parts when they break down. I suggest a tv tech and an estimate.
Dec 29, 2010 | RCA D52W15 TV
How do you stop the tv from ringing? I turn it off and it stops but starts back after you turn it back on.
This is a bad capacitor or high-voltage transformer/power supply that will soon burn out. An ohmmeter will be needed to find the faulty capacitor or high-voltage transformer/power supply.
Jan 10, 2010 | RCA HD52W58 52" TV
Powers off by itself
Hello Sddyardman this problem is coming from the high voltage circuit either from the flyback transformer which can be faulty, the horizontal output transistor or the hv bleeder which can also cause this problem, this is not an expensive repair it is pretty common with projection tv sets after about 5 years or so what i recommend to have a tech come out and service your tv set since this has to do with the high voltage circuit thank you hope this helps.
Sep 01, 2009 | Hitachi 53UWX10B 53" Rear Projection...
POWER WILL NOT STAY ON. IT GOES OFF IMMEDIATELY WHEN TURNED ON
i dont think the v c r has anything to do with your problem the fact that it started turning off and back on indicates that there is a shut down problem starting in your tv ,,it turns off for safety reasons it was made to do just this when there is an over voltage problem with your high voltage section of your tv to keep from any fire starting ,this is its only safety ...so the turning off is indicating that it has a power problem ,i think it would be safe also to say that its not the remote either i think you need to cary tv to shop and have it checked by a rep man but if you know how to trouble shoot the problem i would look in the high voltage area for the problem like the voltage being too high an the annode lead ,,,,the red wire is verry high volts be careful,,,,,,, also some toshiba tv had problems in lv power supply from capaciators being leaky ,,,,,,,
Apr 16, 2009 | Televison & Video
Sound but NO picture
Hello ashleewith2e,
This sounds like a high voltage problem or a picture tube issue (burnt out filament). I would first determine if you had high voltage at the anode of the TV by using a high voltage probe. If you do not have high voltage then I would suspect the voltage doubler, the IHVT (Integrated High Voltage Transformer) or the Horizontal Output Transistor (I doubt this only because you don't have a power supply failure and I would expect this in a modern TV since the high voltage supply is tied to the low voltage supply), the more likely suspect is the voltage doubler. Second possibility I would check is the CRT socket board and CRT filament. Unplug the TV and with a multimeter set to read resistance check to see if the filament pins read a low resistance if so the filament is good. Plug the TV back in and turn it on and check the voltage on the CRT board and compare them to the schematic values. These two tests should localize the issue. Now, If you have a background in electronics, this should be no problem to do, however if you do not have a background in electronics, I would suggest that you have a qualified TV technician troubleshoot and repair this TV set.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 01, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Won't Power On
as you have seen inside that no power & no light. problem seems to be in power supply. 1 check fuse. 2 check switching ckt. 3 check for loose contact or print break. 4 now if you get power on & still tv is not ok then check for hor. output transistor in hor. output stage. if you are not tech person please do not try to fix it as high voltage is there inside.
Sep 23, 2007 | LG 30FZ4D TV
No picture
The power supply or sweep power supply blew up, or the Horizontal/high voltage circuit went bad. If you have no tV repair experience, call in a pro to assist you in this repair. Good Luck
Mar 31, 2007 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
