Question about Hotpoint WMA35 Front Load Washer
Cleaning my machine
I have recently dyed some clothes in my hotpoint washingmacine wma35 the dye has stained the rubber seal between the metel drum and the door and has left resdue in all the creases. Is there a way i can remove the seal to clean it i would apretiate any help
thank you
I have a maytag washer, when i wash clothes ,it is starting to leak from the bottom.can you tell me what the problem is.
Posted on Jul 03, 2008
How to clean the inside seal of a frididaire front load washer
Good Afternoon Friend,
I understand you want to know how to clean the inside seal of your Frigidaire washer, model# ATF7000E. Below are instructions for cleaning the inside of your washer, including the seal:
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer, and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum. Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a nonabrasive household cleanser. This prevents dye transfer to future loads.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Affinity ATF7000E Front Load...
Tip
Allways clean your filter on your washer
by cleaning your pump filter at leased once a month will make your washer perform better and last longer. it will stop problems accuring such as (door will not open ) (the machine will not spin on final spin ) (wet cloths) (un even loads) (dirty cloths) (smell & mould ) another good tip is dry off the rubber door seal after use and sprinkle a little talk powder on it this will stop it staining with mould.
on Nov 06, 2011 | Hotpoint Washing Machines
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
Can i put both whites and colours in a tumble bryer?
Yes, with two caveats. 1) If you put in a dyed fabric that is leaching dye you might get stains on the whites. Anything that has been washed more than three times before should be safe enough. 2) You may end up with some dark lint on your white clothes. You may want to avoid dark clothes that produce a lot of lint, like towels or sweatshirts.
Oct 11, 2009 | Dryers
Dyed washing
TRY TO USE HIGH TEMPERATURE PROGRAME LIKE COTTON PROGRAM WITH 95 DEGREE WITHOUT ANY CLOTHES AND WAIT UNTILL IT FINISH PROGRAMM , DONOT BUT ANY TYPE OF SOAP
THIS LIKE PROGRAMM FOR SELF CLEANING.
I THINK IT WILL BE GOOD !
THANKS
Jun 21, 2009 | Miele Novotronic Premier 500 Front Load...
Black marks all over the rubber seal at the front of machine.
The mould you are referrng to is actually bacteria that is building up because you are doing too many low temp washes.
What you must do is a high temp wash periodically,with powder in but no washing.
Do this 3 or 4 times a year, more if you do a lot of wahing.
It is called a maintenance wash, and helps kill off the bacteria.
With a scouring pad or steel wool pad, clean as much scum as you can off the door seal. particularly in the folds of the seal.
You will probably be left with stains in the rubber, but as long as you have got the worst off, it should be o/k.
Please rate my solution.
Thanks.
Jan 21, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Cleaning rubber seal
Use a 1/2 cup of vinegar and pour it onto the rubber door seal.  Let it sit awhile then wipe dry.  The stains are very hard to get off once they're on.  You can also use baking soda to remove the odors.
Jul 21, 2008 | LG WM-2077C Front Load Washer
Ruining cloths, leaves black stain.
Black stains could only come from rubber part that is deteriorating. Need to check all hoses, rubber boot and at bearing seal.
Dec 11, 2007 | GE WCVH6260F Front Load Washer
Stains on clothing
Usually black oily stains are a symptom of a rear main drum bearing starting to go bad. The seal goes bad first and the packing grease will start to weep out as water gets into the bearings. Is the washer starting to get loud during any spin cycle? If so, I think your bearing is starting to go. It's not a cheap fix, either. The whole back shell of the outer wash tub has to be replaced because the bearings are molded into the plastic. I hope this is helpful in some way.
Jun 11, 2007 | Kenmore 43052 Front Load Washer
Hotpoint WMA35 Front Load Washer Logo
73 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
