Question about Dell Inspiron E1705 Notebook
Bluetooth how to activate the bluetooth function?
    Problem Solver:
  • 7 Answers
To activate the bluetooth function - try pressing the fn+ F2 key at the same time. If this does not resolve your problem, you can go turn on the outside physical switch which when toggled will turn on / off the wireless and bluetooth services.
Should this STILL fail to resolve your symptoms, go to Dell.com - and search on your model number, when you see your PC link appear, select the owners manual and do a search for the bluetooth function and it will review your options again there. You may need to download the most current drivers from there, in order to have the functionality restored. Good Luck!
Posted on May 16, 2010
How to activate bluetooth in a leptop
Check to see that the laptop has a Bluetooth adapter installed. Click on the "Start" menu in the lower-left corner of the desktop. Click on "Control Panel." Click on "Performance and Maintenance" and then on "System." Click the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Look for a small blue icon that says "Bluetooth Devices." Click on the "+" next to it to expand the menu. There should be at least one Bluetooth device listed. This indicates that your laptop has a Bluetooth adapter. Turn on the Bluetooth device by locating the physical or software switch that activates the adapter. Check the outside edge of the laptop for a button or switch that is labeled "Bluetooth," shows a picture of the Bluetooth icon or is labeled "Wireless." Turn this to the "On" position. If no physical switch exists, check the function keys on top of the keyboard. Look for one that shows a wireless symbol. This may look like a small antenna with waves radiating out from the top. Hold down the "Fn" or "Function" button and press the corresponding function key until the computer indicates that Bluetooth is turned on. Locate the Bluetooth icon in the system tray in the lower-right corner of the desktop. It will match the appearance of the Bluetooth icon you located in the Device Manager. It may have a red symbol in the center that indicates that the Bluetooth is turned off. Right-click on this icon and choose "Start the Bluetooth Device" from the menu. Test the Bluetooth by connecting a Bluetooth device. Right-click on the Bluetooth icon in the system tray. Use the "Quick Connect" option or follow the Bluetooth setup wizard accessed through the "Add a Bluetooth Device" option. Hope this helps.
b>
Dec 13, 2012 | Lenovo 3000 N100 Notebook
The light for the bluetooth system in our 2012 VW Sportwagen isn't turning on, and the phone is not showing up on the multi-function display in the gauge console. It will not power up with buttons on
Check the manual.There should be instructions on how to pare the 2. Make sure Bluetooth is on in the phone settings and is also abled to be discovered.
Nov 09, 2017 | Cars & Trucks
Want to use bluetooth on my mini 1012 I tryed to
Go to control panel and see if you can find the bluetooth driver. Enable this and it should function.
Sep 21, 2011 | Dell Mini 1012 Netbook
Lhow can i install Bluetooth driver for hp compaq nx 7300
Active the bluetooth module by clicking on the FN [Function key] and the wireless key, this will activate the bluetooth hardware, please note that your bluetooth driver needs to be installed to working correctly
Sep 08, 2011 | Computers & Internet
How can i change my wallpaper and how can i activate the bluetooth function?
Chances are you have the version that comes with Windows 7 Basic that does not allow you to change the background of the laptop. The bluetooth functionality should already be there assuming that you have the bluetooth module.
Sep 06, 2011 | HEWLETT-PACKARD Mini 110-3018cl Netbook
How do i turn on my acer aspire 4738 laptop bluetooth device on?
Here are steps:
Download the bluetooth driver from acer website
Install it restart your pc
Then press the bluetooth button which is on the top(above function keys)
Then right click on the file you wanna send through bluetooth then send via bluetooth
bluetooth adapter driver ENGLISH version
http://support.acer-euro.com/documents/reports/blue_share_eng.pdf
you will need to connect your bluetooth device with a usb lead then make both your computer and the bluetooth drvice discoverable also you might downoald software
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you. The BluetoothView application was designed to be a small tools that runs in the background, and monitors the activity of Bluetooth devices around you.
hope this helps you
Aug 25, 2011 | Computers & Internet
Bluetooth activation
go into your phone's menu and go to settings; look for connections; the bluetooth menu should be there; turn bluetooth on; put the device that you want to pair in pairing mode; and then have your phone search for the bluetooth device.
Jan 31, 2010 | Siemens AF51 Cellular Phone
Bluetooth Activation Toshiba satellite pro L300
Method 1 :  FN+F8 function should enabled the BT and should stay in this position. Then the BT could be always on.
Method 2 : Start menu -- Run -- Type " fsquirt.exe " without quote. it will automatically find the drivers and activate your bluetooth only if you have the Bluetooth driver installed.
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
I have a samsung impression and it will not connect the bluetooth. I have been trying for almost an hour and all it says is activating bluetooth. What do I do to fix this
are you at home? if you are out of country the roaming function can take over the bluetooth function. also check the bluetooth settings to ensure that the phone is not hidden and is open connectivity.
Dec 01, 2009 | Samsung SGH-A877 Impression Cell Phone
http://www.itec.fo/UserFiles/File/TravelMate%202410.pdf
WPAN: integrated Bluetooth® (optional)
this could mean that you do not have it installed.
f6e793f.jpg Look closely at the front of your laptop
Button 2 is yoru blue tooth button
Press to enable/disable the Bluetooth
function. Indicates the status of
Bluetooth communication
Feb 15, 2008 | Acer TravelMate 2300 Notebook
Dell Inspiron E1705 Notebook Logo
193 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
