Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Continual beeping My refrigerator continually beeps. It's the sensor for "open door", but the doors are closed, but still beeps every 30 seconds or so. Help!
  • maddysmother May 16, 2010
    MacMarcus - I think I see what you are saying. I opened the top compartment at the top of the cabinet. I just can't see where the sensor's are. I see where the nob is pushed in to indicate an open door, but I don't see where there are magnet connections. You don't happen to have a photo so I can see what I'm looking at? I checked, and all electrical attachments are secure. Any other ideas? :-) - Erin
  • Kenmore Master
  • 2,605 Answers
Hi, welcome to Fixya A very common problem with those fridges actually. Check to make sure the door sensor`s are secure and contacting each other when the door is closed. You can do this by accessing one or both sides of the door sensors at the hinge assembly cover at the cabinet top. There should be sensor`s on either side which sense when the door is closed by "making" with magnets on the doors. They sometimes become loose from where they are held in place and therefore do not indicate the door is actually closed. That is the most likely cause. If this does indeed help you solve your issue please take a moment and rate it accordingly. If it doesn't solve the problem let me know and I'll try and assist you further. Thanks for visiting "fixya" today. good luck. macmarkus :)
Posted on May 16, 2010
  • Mark MacDonald
    Mark MacDonald May 16, 2010
    Hello again,
    You actually answered what was going to be my next question. The "knobs" are the second type of door sensor/light actuator, the other type I was referring to are on many models, just not yours obviously.
    The next thing to look for would be this, with the doors closed see if you can manage to "peek" through one of the door gaskets from the side to determine if the cabinet light is on or not. ( can be done by carefully lifting the gasket via a dull knife or screwdriver ) You can also use a small camera phone or handy-cam etc. placed inside the fridge to see if the light stays on.
    If it is staying on, there can be an issue with the door switch itself, check the switch by pushing it in with the door open and see if the light goes off. If it is shutting off, but not when the door is actually closed then that would lead me to believe the door is not pressing the switch into the closed position or the control board is faulty.
    If it is pressing the switch in yet the light still will not go out, you have a loose connection at the door switch ( under the plastic hinge cover) or a control board problem.
    There has been a repair tip on those units issued by sears if this is the issue. You would need to contact sears service ( 1-800-4my-home) with your model and serial number and indicate to them this, in these words...
    "the light inside the cabinet does not turn off when the door is closed". Ask them to please search for the repair tip/update regarding that issue. You may need to persevere and be tolerant as many of the call center reception people do not speak fluent english anymore. I know the call center for Sears Canada ( where I am ) is actually located in the Philippines.
    The repair tip includes new light socket and wiring harness with hi-limit cut-out/safety, heat deflector, lens cover, user interface housing and a new pcb.
    If left in it's current state it will eventually melt the plastic liner inside the fridge as well as a potential failure of the electronic controls as well.
    I currently work for Sears and I see a lot of these. Let me know what you find out and I'll see if I can actually find that repair tip reference number, if I can sort through my files in my van. Any sears tech who phones the tech. assist line should know of this anyway.
    Good luck.
    macmarkus :)
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
How do I fix the continuous beeping coming from my refrigerator?
LG Fridge Door Alarm ' Chris Inch
www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
www.applianceblog.com/.../17546-Frigidaire-Professional-Constant-Bee...
Jan 15, 2010 - 10 posts - ‎3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
Feb 03, 2016 | Refrigerators
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 11, 2015 | Frigidaire Refrigerators
MF12568aes "door open" light keeps beeping when all doors are shut
Wipe down the contact area on the door and corresponding area of the inside of the fridge. if this doesn't work, there is a faulty connection to the sensor inside the refrigerator that will require a service call. Not something a lay person should attempt to repair, as trying to fix yourself will probably void any remaining warrantee on the item. Good luck
Jan 23, 2013 | Maytag Refrigerators
My fridge beeps intermittanly
Hello, when a fisher and paykel is beeping it is usually beeping due to a door being open or ajar or the switch that interacts with the door closeing being at fault. First check your seals and assure you have no rips or tears in the seal. Secondly you would check the switch that the door closes against usually the small black strip on some of there models. If you need me to bring up your schematic to show where your switch is located message me back your model number of the machine. Also if you have any further questions message me back those as well. Another question for you is if you look on the rear wall of the freezer do you have any frost built up if you did this would be called a defrost issue that your unit was having. Most of the time though the beeping sound is due to the switch for the door shorting and after it does short tells the control that the door is open. I await your reply if you have any further questions and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks,
Rick
Aug 23, 2011 | Fisher and Paykel Refrigerators
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Beeping sound
ok the only other option the latch located in the fridge has a loose wire which need to repaired by a fridge tec but also if the fridge seems like its not getting cold the thermostack that make the fridge cold may be malfunction
any how it needs repair
Jul 07, 2008 | GE Profile¿ Arctica® Energy...
How long does the door alarm continue beeping after the door has been left open for 2 minutes? We have Model PDS22MBWCC. Thank you.
The door alama will sotmd if either
door is open fin" more than 2 minutes.
The beeping stops when w)u close
the door.
May 09, 2008 | Refrigerators
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
408 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
