Question about eMachines 15 inch Monitor
Monitor powers on but within a few minutes I get the message"NO SIGNAL" and the monitor shuts down and won't power up again unless I unplug the power cord and then it does the same thing over again
  • Eugene McGuire May 16, 2010
    I found a capacitor to be lose inside of the PC and the monitor is working correctly now. How long it will last I don't know. But if it occurs again, then I will try your 2 solutions.
    Thank you
  • 6,487 Answers
Base from the description of your problem this is a clear sign of a monitor that is already getting bad and for this type of problem its really recommended that you rather have the monitor replace than having it fix for some part replacement since the price will be as much as the same when getting a new unit.
Posted on May 16, 2010
    I have replaced the power cord and the PC cord. The monitor works perfect on another PC but will not work with the emachines pc. Monitor is model500G
  • Mark Gil
    Mark Gil May 16, 2010
    Ok thank you for the additional Info , if that's the case better if you can try a different monitor to that computer because this can also be a problem with the power supply unit of that computer that is failing, So if you already tried a different monitor and still same problem the 2 possible cause is the power supply or the video card of the computer.
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
The power button on my HP monitor keeps getting a message saying "Power button lockout" and the monitor will not turn off whenever i push the power button it just goes to sleep and i have to unplug it and...
Hold down the power button on your monitor, with the power on, for approx. 25-30 seconds and the monitor will shut down for good. When you will start it again, wait at least an hour, the message will be gone and the monitor will work as intended.
Jun 23, 2010 | Computers & Internet
I live in Seattle and have an Acer V193B that 'went dark' when I hot-pluggged the VGA connector into my laptop. I *assume* the problem is the chip that buffers the VGA lines is blown. (I know the cable and...
maybe a short circut happened and fried your monitor's decoding unit... There probably is nothing you can do to fix it and you can't really do anything with it other than trashing or potentially expermenting with the thing, but bewarned, It may jump back to your laptop...
Oct 01, 2009 | Acer V193 B LCD Monitor
Shuts down after a few seconds
hi there, check your power supply on cpu if theres a tripping off , so if theres then replace power supply. then switch it on again. then let me know what happen nexr..
reagards rated me... thanks
Mar 31, 2009 | Acer AL1715 17" LCD Monitor
Emachine Monitor comes on a few minutes and cuts back off
I have the same problem and I think its the circuit board on the power on button and blue led. I unplug the board when the monitor is on and then the monitor stays on and works OK.
It don't make any sence it is only 3 parts switch led connector
anybody else run into the problem
Mar 29, 2009 | E-Machines eMachines Monitor E15T4
Dell SP2208WFP Flat Panel Monitor goes straight to power save mode
If the monitor is not turning blue that means it isn't picking up on the signal that is coming to it.
Pushing the power button on the monitor should make the monitor work and give you a no signal note if it isn't getting signal.
If it won't power on with its own power button you maybe having a low voltage problem in the monitor itself which isn't giving it enough to fire up after it has been sitting.
Just a note these monitors use and make power even when they are off, unless they are unplugged.
I'm thinking along this route also because when you said you unplugged it for a while that it did turn back on.
Only way to verify it, is to double check the monitor on another computer. and if it is the same then it will have to come apart.
Power issues are very common in lcd monitors, Lots of heat in a confined space. The bigger they get the hotter they get.
You would think they would have incorporated internal fans in these by now. But then they wouldn't sell as many !!!
bammbammfran
Search and you shall find me !!
Oct 14, 2008 | Computers & Internet
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Monitor comes up shows "acer" then says no signal and goes black
1 Take the monitor out to the street
2 Raise above head
3 Hurl it twards the ground
4 Release
5 Watch peices fly everywhere
6 Enjoy a cold beer
7 Go out & buy a nice new monitor ( not a acer product )
Feb 18, 2007 | Acer AL1916W 19" LCD Monitor
Open Questions:
Norton Tech Support Number 1*888*866*2O82 Phone Number for Norton Technical Support Norton Tech Support Number 1*888*866*2O82 Phone Number for Norton Tech Support, Norton Tech Support Number Norton tech support phone number 1*888*866*2O82 Norton Tech Support Phone Number Norton Tech Support Number 1*888*866*2O82 Norton Tech Support Phone Number Norton Antivirus contact number, Norton Antivirus telephone number.Norton not working, Norton troubleshooting phone number, Norton troubleshooting support number Norton tech support, Norton tech support number, Norton tech support number usa, Norton customer service chat, Norton internet security customer service phone number, Norton numbe number customer service Norton antivirus phone Norton 360 support number call Norton antivirus Norton 360 contact phone number Norton Antivirus phone number, Norton Antivirus support phone number, Norton Antivirus techncal support phone number.Norton help phone number, Norton help number. Norton help desk number, Norton help desk phone number, Norton tech care number, Norton tech care phone number, Norton tech support telephone number, Norton technical support telephone number, Norton phone number phone number, Norton not working, Norton troubleshooting phone number, Norton troubleshooting support number Norton tech support, Norton tech support number, Norton tech support number usa, Norton customer service chat, Norton internet security customer service phone number, Norton number, phone number Norton Antivirus tech support Norton phone number Norton support phone number Norton tech support number Norton technical support number Norton customer support number Norton customer SUPPORT number Norton customer care number Norton toll free number Norton helpdesk number Norton contact number Norton telephone number Norton support phone number Norton tech support phone number Norton technical support phone number.
May 21, 2018 | Norton Computers & Internet
norton help desk USA&Canada -1*888*866*2O82 Norton support phone number Norton antivirus tech support phone numberNorton Phone Number norton help desk USA&Canada - 1*888*866*2O82 Norton support phone number Norton antivirus tech support phone numberNorton Phone Number Norton contact phone number contact number for Norton antivirus contact number for Norton Norton antivirus technical support Norton antivirus customer support number phone number for Norton antivirus support Norton help chat call Norton Norton customer support phone number Norton antivirus canada Norton antivirus contact phone number Norton online support Norton antivirus 1800 number contact Norton internet security telephone number for Norton antivirus telephone number for Norton antivirus customer service Norton internet security tech support phone number Norton symantec support contact Norton antivirus customer service phone number Norton internet security contact phone number contact Norton 360 Norton tech support number Norton help phone number phone for Norton customer support Norton internet security customer service Norton antivirus help phone number Norton security help phone number Norton antivirus customer care number phone number for Norton 360 telephone number for Norton security Norton antivirus telephone number customer service Norton internet security contact Norton virus protection contact number Norton internet security help Norton virus phone number Norton customer support telephone number Norton antivirus phone support Norton by symantec phone number telephone number for Norton internet security Norton support contact number Norton internet security customer service number Norton phone number customer service call Norton antivirus customer service Norton antivirus help desk phone number Norton antivirus phone number support contact number for Norton internet security phone number for Norton internet security Norton antivirus help desk number Norton antivirus customer support Norton phone number support Norton tech support Norton contact Norton contact support Norton 1800 support number phone number Norton antivirus customer service number for Norton antivirus Norton telephone support call Norton security Norton antivirus customer care phone number Norton antivirus online Norton online help Norton security helpline Norton install Norton telephone number customer service Norton antivirus phone Norton tech support chat call Norton antivirus Norton internet security technical support phone number Norton antivirus customer service telephone number Norton antivirus support telephone number Norton com phone number Norton antivirus help number
May 21, 2018 | Symantec Computers & Internet
See all eMachines 15 inch Monitor Questions
eMachines  15 inch Monitor Logo
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
