Question about Ford Garden
Looking for a wiring diagrahm for my ford lgt 125
Some of the wiires are cut and spliced together and wont start
    President:
  • 1,627 Answers
You should price out a wiring harness,they are usually not that expensive and can be replaced fairly easily,may be the cheapest way out of your problem.
Posted on May 17, 2010
Autopage alarm rf 220
IT IS POSSIBLE THAT THE ALARM HAS FAILED. WHAT YEAR IT THE TRUCK. THE WIRING WILL BE AT THE KNEE BOLSTER. YOU WILL SEE A YELLOW HEAVIER GAGE WIRE THAT IS THE IGNITION WIRE.THE WIRE WILL BE CUT AND SPLICED INTO THE ALARM WIRING . JUST CUT AND SPLICE THE WIRE TOGETHER AND SEE IF IT STARTS. DEPENDING ON THE DETAILS OF THE TRUCK YEAR AND SUCH. WIRE CAN CHANGE COLOUR, POST TRUCK DETAILS AND I CAN POST WIRING DIAGRAM.
Jan 22, 2014 | Vehicle Parts & Accessories
Ai-NET cable is cut, wire splice male aux cord
On the ai net cable identify and separate strand with green, blue and unshielded common/ground. G and B will be your positive which you will then solder to red and white leads from rca or headphone cable with unshielded from that cable twisted together and soldered together with the unshielded wire from ai net cable. Tape off or heat shrink the rest of wires from ai net cable.
Sep 29, 2013 | Alpine CDA-7863 CD Player
MY CAR WONT START BECAUSE IN AFTER MARKET ALARM. hOW DO i BYPASS THE ALARM TO START THE CAR
I've ran into this problem myself, if you're not confident with doing some wiring you probably should not be doing this. This will probably take 1 to 3 hours to do this. If you can get a wiring diagram that showed how the alarm was originally installed. If not find the alarm probably underneath the dashboard, the alarm wires will problem be smaller than a wiring that is in your car. When removing the alarm think of it as this way, someone cut into the middle of your wiring harness and put a alarm in. Would you need to do is remove the alarm and splice the cut wires back together. Instead of removing the alarm all at once try disconnecting one wire in a time and finding its mate. The wires or color coded. For example, black with an orange tracer. This would mean it's a black wire with an orange line on it. If you're not sure look at a wiring diagram splicing the wrong wires together could cause your car not to function properly or damage it. Before you start this make sure you disconnect the battery also. Good luck.
Jul 18, 2010 | 1998 Ford Mustang
No power at all in any cycle have electric to it.
Check the lid switch.....make sure the switch is being pushed all the way in. On some models there is a fuse, usually wired in somewhere near the lid switch, check the fuse and make sure it isn't blown. If there is no fuse you can also check the switch by cutting the wires running to the switch: strip the wires about a quarter inch and wire nut them together....cut the wire at the switch so that there is enough wire left to splice back together if the switch isn't the problem....if you cut the wire too close to the switch it is a pain trying to splice the wiring back together. If your problem is a bad lid switch the washer should come start working. Good luck
Jan 13, 2010 | Maytag Washing Machines
Truck wont start lights work stero wont turn on when the key is turned on
Sounds like your fusible links are bad. There are two down at the starter. They look like a rubber plug in the middle of the wire, just cut them out and splice the wires back together. If they have been cut out, then check them for corrosion and clean them up. Use heat shrink tube instead of tape to cover the joints. It seals better.
Jul 12, 2009 | 1984 Chevrolet Chevy
Negitive wire on stater
Use a **** connector and heat shrink wrap.
Jun 24, 2009 | 1991 Ford Explorer
My computer speaker wire has a short.
The audio cables normally have only two wires in them, one being shielded the other not. You should be able to splice the two together to fix the problem, if there is no colour coding you wont cause any damage to anything if you get them back to front the first time round guessing.
Mar 16, 2009 | Dell Computers & Internet
Wiring diagram for ford focus 2005 ghia 1.6
If you know which wires they are, ask an electrician to "but-splice" the wires back together.
Or if you think yourself wise enough to handle the situation, go buy, wire-strippers, **** splices and a crimper for those wire splices.
MAKE SURE YOU GET THE RIGHT SPLICES FOR THE GAUGE WIRE.
Strip the ends of either wire(you only need to strip about a1/4 inch), twist them CLOCKWISE, place them in the **** splice, and crimp the ends, and PRESTO! wire has continuity.
Make sure you splice the right wires together, or you will have blown fuses, and things not operating correctly.
Oct 07, 2008 | 2005 Ford Focus
Garden Logo
224 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
