Question about Schwinn Scwhinn 26 Inch Womens Coronado Bike
Cant the handle bars on the bike ,,,not sure if the cyclindrical bar come off? screw appears to be on top, just does not turn...or am i supposed to prey open the handle bar attachment and then aqueeze it tight ?? this would be on the 26 inch ladies bike
  • 632 Answers
Don't pry it, just loosen it up and spray wd40 lube then let it lay on it's side to work the lube in. If it doesn't work use a rubber mallet and give it a few whacks on the bolt, this might break to hold from the handle bars. If it still doesn't work use a cold shot spray found in electronics store and let the aluminum contract from freezing it.
Posted on May 16, 2010
I feel like I'm missing something. I can not attach the handlebars to the bike. I have one long screw, a bolt and some small black cylinder cut on an angle. The instructions are not helpful because...
the cylinder cut on an angle is what the long bolt should bolt to, put the cylinder below the handle bars, and drop the long nut down through the handle bars and into the cylinder, ( the hole in it should be threaded,) only start the bolt so it hangs onto the cylinder, then feed that into the top of the neck hole, where the handle bars slide into,, once the desired height is ok,, tighten that bolt, the cylinder will come up at an angle and tighten the neck and handle bars !! Good Luck
Jul 02, 2011 | Dynacraft Girls 16" Barbie Bike
Trying to put chain and saw together
If the saw has a chainbrake make sure it is de activated by pulling the hand guard fully to the top handle, you should hear an audible clip when it locks, remove the the bar nut/nuts and remove the side cover, if the chain adjuster is in the cover screw it right back, if the adjuster is in the crankcase screw it right back, place the guide bar onto the bar bolts, loop the chain over the sprocket and lay it around the guide bar with the cutters on the top of the bar facing away from the saw, if the adjuster pawl is in the crankcase locate it into the adjuster hole in the guide bar, now re fit the side cover, if the adjuster pawl is in the cover make sure it locates into the adjuster hole in the guide bar, re fit the bar nut/nuts finger tight, screw the adjuster up until the chain sits snuggley around the whole guide bar, pull the chain around the bar manually with a gloved hand, this will make sure it turns freely and is correctly located in the sprocket, hold the end of the guide bar up and tighten the nut/nuts
Jan 23, 2011 | McCulloch Garden
I have a question about putting together a disney princess 12in bike, I put the handle bars in, but they don't seem to attch to anything. And the owners manuel is for multiple different bikes, so it is not...
If I understand your question, you put the handlebars into the front steering assembly but they don't attach.
On top of the handle bar is a screw that when it is turned in pulls a wedge shaped bottom piece up. When this is done once the handlebars are in the steering unit, the handlebars lock up and can't rotate or pull out.
If that doesn't answer your question, let us know.
Gary
Dec 21, 2010 | Huffy 12 in. Girls Disney Princess Single...
Need to raise the handle bar on my 2007 Marin Argenta road bike.
The stem for the marin is fixed so you'd have to replace it with one that is higher if you wanted to raise the elevation of your handle bars. You can pivot the handle bars for your preferred angle of comfort though. Loosen the 4 screws on the top of the stem and then you can adjust the handle bars to the correct angle that is best for you.
Jan 09, 2010 | Cycling
How to attach hand brakes? how do i loosen handle bars to adjust?
The bolt you see right above where the handle turns is the handle bar clamp. And if it's been on a while you'll need to take a piece of strong wood and hold it on the bolt, when it's lossened a bit, and hit it with a hammer to fully loosen the handle bars.
Hand brakes should come with clamps to put on the hadle bars, and if you look at bikes that have hand brake, you'll see how to route the cable. The only problwem is if your bike doesn't have the part taht the brake would screw to at the wheel. Then you'll have to improvise.
Dec 22, 2009 | Mongoose 20 in. Boys Axe Bike
The housing of my brakes on the handle bars is loose and keeps moving. how do i tighten it so that it stops moving when i apply pressure on it and/or squeeze the brake lever??
If the screw is all the way tight and still slipping ... try to find a fatter part of the handle bar to mount the grip to. You will probably will not find any such that is convenient for you to continue to use the brake ... remove the grip, wrap some electrical tape around the handle bar, reattach the grip. Tighten it and give it a try.
I hope this works for you
a
Oct 12, 2009 | GMC Denali Road Bike
I fell on my bike and the handlebars and stuck to the right side.
Depending on the bike, you will most likely have a nut at the top of handlebar stem or two socket screws at the side of the stem that grip the front fork. In either case you need to loosen them slightly, reposition the handle bars and then tighten up. Quite often however if you stand in front of the bike with your legs on either side of the front wheel and turn the handle bars their is enough slip to move them back. Be carefull you dont strain anything if you dont back the threads off.
Sep 03, 2009 | Cycling
Diamondback rm 20 kids bike. Can you adjust the handlebars?
Yes, there is an allen screw on the top of the stem of the handle bars.....it may also be a bolt with a head on it that can be turned with a socket or cresent wrench.
Loosen the bolt 3 or 4 complete revolutions and then wiggle the bars back and forth from side to side while pulling up. Be careful not to completely remove the screw as the piece that it is connected to will fall off and you will have to remove the bars completely to fix.
May 02, 2009 | Cycling
I need to raise the height of my handle bars.
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Ed
Feb 01, 2009 | Schwinn Mesa Gs Mountain Bike
Schwinn Scwhinn 26 Inch Womens Coronado Bike Logo
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
