Hdd password blocked
I am usind toshiba 40 gb hard disk, now when i boot my system it asks for a password and after 3 wrong attempts it blocks and i have to reboot and the same contineous. i by mistake blocked my hard drive with a passwor, now i want to know how can i bypass the password or erase the disk, so atleat i can use the hard disk.
  • 655 Answers
There are a number of methods that can be used to bypass or reset the BIOS password, like
  • Using a manufacturers backdoor password to access the BIOS
  • Use password cracking software
  • Reset the CMOS using the jumpers or solder beads.
  • Removing the CMOS battery for at least 10 minutes
For a free software to reset BIOS Click Here:
For more information please check out my solutions, i have allready given some tips on this issue.
Thanks
Iqbal
Posted on Apr 01, 2008
My Toshiba hard disk is not functioning well
Hi,Dear Customer,
1> Please check you HDD cable connector.
2> Where from connect HDD cable in mother board, this port change and be care fully connect.
3> Check HDD bad sector. If you hard disk create a bad sector then not well run any hard disk.
4> Check jumper setting, first boot & sec Boot option. you hard disk where connect first boot & sec Boot option.
I think solve you problem.
Sep 12, 2012 | Toshiba Computers & Internet
Can't unlock My Essentials 1TB Hard Drive Asking for password and I don't have it.
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 26, 2011 | Western Digital My Book Essential Edition...
Was installed in a Dell Laptop and someone set the Password on it. Now need to move it to another Inspiron 6400 but it is not able to get past the menu at the start asking for the Disk Password to be...
Hard disk passwords protect data on hard drives and moving the hard drive into another computer will not unlock the hard drive unless you have this password.
There are no backdoor password available.
Dec 14, 2010 | Toshiba 120GB MK1237GSX 2.5" SATA II 120...
Acronis Migrate easy cloned hdd doesn't load win xp
You can use AOMEI Partition Assistant to clone your 60 gb hard disk to your 160gb directly. you can also use it to migrate your os to another disk if you don't want to clone the entire disk. http://www.disk-partition.com/copy-disk-partition-wizard.html
Sep 06, 2009 | Acronis Migrate Easy 7.0 Full Version for...
Cant boot
If you are sure no one has tampered with it and entered a HDD password and it is not prompting for a password then it is most likely a HDD failure. It is possible the BIOS will still recognize the HDD. Try disconnecting and reconnecting the HDD if you can access it there should be screws on the bottom marked with a cylinder symbol.
Jan 24, 2009 | Toshiba Satellite A205-S4617 Notebook
Transferring to another notebook HDD and finding problems
did you copy your operation system onto your new hard drive? Must of the time they a hidden file that the manufacture does not want you to find. If you did the you may have to go to your bios and make sure that it's set to boot from your e dr1ive first because that 's where the operating system is on.
Dec 22, 2008 | Computers & Internet
SAMSUNG IDE HDD SP0411N (40GB)
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Jan 06, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Hdd password
What is HDD Password? All hard disk drives have the possibility to set a hardware password, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. When you set a password on your notebook, the drive becomes locked as well. XBox gaming consoles and some desktop computers can also lock hard disk drives. This is usually called "HDD password" or "ATA password".
If you forget the original HDD password, there is no way of restoring it by generic system tools. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow to remove an unknown HDD password and make hard drive usable again.
I have a software enable to reset the password security on your harddriver but you need to pay my professional charge. If sound interested please email diazphi@gmail.com.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 30, 2007 | Toshiba Satellite Pro 6000 and 6100 14.1...
Computers & Internet Logo
935 people viewed this question
David Payne
David Payne
