Question about Samsung Vacuums
Re Samsung Cannister Vacuum cleaner. On off Switch
Re Samsung Cannister Vacuum cleaner Model VC8913. On off Switch doesn't stay on when pressed. How do I get access to it. I have removed 3 screws from the top, but the top does not want to come off?
  • 652 Answers
There should be plastic clips on the bottom of unit, you may need to push them in as you lift the top off.
Posted on May 18, 2010
  • 952 Answers
Thanks for using FixYa.
You need to exert force when trying to take the top off since it will be the first time for you to take it off.
I hope this helps. Thanks and good day.
HotRatchet
Posted on May 16, 2010
  • wayne_walz May 16, 2010
    There seems to be something holding the top section to the base at the back. Are there additional screws under the switch actuator plate & the cord retracter plate. If so, how do I remove these plates?
    May 16, 2010
How to Unclog Vacuum Hose
you may have to make something out of heavy spring material so you can push it down the hose and be able to manipulate it.simular to what plumbers use.
Aug 14, 2014 | Hoover Vacuums
I need a manual for Royal 4600 cannister vacuum
I have a PDF from Royal for you.I would be happy to email it unless it is possible to post it here..?
Jun 08, 2014 | Royal Metal Canister Vacuum Cleaner Upper...
Doesn't seem to be sucking up dirt well
Bagless vacuum cleaners leave the bulk dirt in a receiver, but they still rely on a paper air filter to trap fine particles of dust. All the air that the vacuum moves passes through that paper filter. When the filter plugs up, it has to be cleaned or replaced. The bagless "primary filters" are much more expensive than vacuum cleaner bags, but if you can afford to replace it whenever the machine's suction is impeded, its the tidyest solution. You can remove the filter and tap it inside a waste can to dislodge some of the dirt that's plugging it. You can use another vacuum cleaner to clean it somewhat better than just tapping it. (It doesn't have to be *your* other vacuum cleaner, it could be borrowed, at the car wash, etc.) You can use compressed air to almost all of of the dirt plugging it, but you'll want to do it outside somewhere that making a clod of dust is acceptable or at least unnoticed. After a dozen or more cleanings the pores of the paper filter will become too plugged to clean well even with compressed air and it will have to be replaced.
Pet hair, sand and large particulate are least likely to plug these filters. Kitty littler, which is pressed pellets of fine clay, clogs these filters very rapidly. The clay pellets break up into very fine dust as they pass through the vacuum and whirl in the dirt cannister. Avoid vacuuming kitty litter, or any other fine clay into a bagless machine as much as possible.
Jul 28, 2012 | Hoover S3765-040 WindTunnel Bagless...
My dyson will not turn on
make sure electrical out let has 120 volts, try another out let if all is good.electrical cord at the plug in prongs could have a short in cord.the control switch could be faulty and make sure vacuum bag and cannister in place tight.i remember some of 1960s and late model electrolux vacuum cleaner if the vacuum bag container door wont closed all the way vacuum cleaner wont turn on.
Jan 23, 2012 | Dyson DY500 Bagless Upright Cyclonic...
Electrolux vacuum cannister bag is not full, but vacuum will not stay on.
How long does it run when you plug it in....or does the on and off switch not work?
Jul 27, 2011 | Electrolux Guardian Bagged Canister Vacuum
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Jan 04, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Vacuums Logo
Top Samsung Vacuums Experts
woodzowl307
ray gallant
GARY HIVELY
Level 1 Expert
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
