Question about Jwin JD-VD130 DVD Player
Got audio no video
I have no video i have sound
  • Locate a button labeled Progressive, PS/IS, PS, or IP on your DVD remote control.
  • Press and hold the button until MULTI, AUTO or INTERLACED is displayed on your TV.
  • Posted on Aug 02, 2008
    • 813 Answers
    Chak ur video op cable u plug it on worng socet
    try onther socet to plugin
    Posted on Mar 31, 2008
    SOURCE:
    WHAT DOES IT DO I HAVE NO IDEA HOW DOES IT WORK?
    A sound card (also known as an audio card) is an internal Computer expansion card that facilitates economical input and output of audio signals to and from a computer under control of computer programs. The term sound card is also applied to external audio interfaces that use software to generate sound, as opposed to using hardware inside the PC. Typical uses of sound cards include providing the audio component for multimedia applications such as music composition, editing video or audio, presentation, education and entertainment (games) and video projection.
    Sound functionality can also be integrated onto the motherboard, using components similar to plug-in cards. The best plug-in cards, which use better and more expensive components, can achieve higher quality than integrated sound. The integrated sound system is often still referred to as a "sound card". Sound processing hardware is also present on modern video cards with HDMI to output sound along with the video using that connector; previously they used a SPDIF connection to the motherboard or sound card.
    I hope this helps you.
    Apr 29, 2016 | Computers & Internet
    Why do I only have audio and no video? All I have is a black screen.
    Search Results
      You Tube ... no video, only sound. [Solved] - CCM
      ccm.net > Forum > Software > Video software
      Apr 13, 2014 - Youtube no video only sound · Youtube no video only audio · Youtube no video ... The steps for other browsers should be similar, but Google if youcan't find it. Answer ... 10 Hidden Signs You Have a Thyroid ProblemVitality.
      How to Troubleshoot Audio and Video Issues in Windows ...
      https://support.microsoft.com/en-us/kb/265523
      Microsoft CorporationIssue: The audio plays, but the video does not, or vice-versa. ... Verify that you havethe correct and up-to-date drivers for your sound card. The use of incorrect or ...
      Only the audio plays when you play a video file in a ...
    Jan 18, 2016 | Televison & Video
    How do I hook up my 55 inch led tv to a stereo for better sound
    In many cases newer tv's do not have an audio out, some have a headphone jack on the side (Small usually blue)
    Otherwise if you are wanting to get better sound from a DVD / Blueray / Satellite / Cable box, You can put the audio from these devices into your sound system, then plug your sound systems audio out into the tv.
    The video out from your devices will need to connect directly into the tv.
    If using HDMI or S-Video that carries both audio and video, slitter / separation boxes are available, but usually degrade sound and audio quality.
    The above would look something like
    Cable box audio out (red / white) to Stereo audio IN. >> Stereo Audio OUT to TV audio in.
    Yellow (Video) Cable from cable box then goes directly to the TV Video IN. Just make sure the audio and video cables are going to the same section (Some tv's may have multiple audio / video in's
    Nov 17, 2014 | Haier LE55B1381 55 Class LED HDTV - 1080p,...
    Wiring color code for lcd screen
    AV VIDEO CABLEYellow- Video Red- Right sound R White- Left Sound L
    Component Cables RED ORANGE- video BLUE- video GREEN-video RED- audio R WHITE-audio L
    HDMI provides both video and audio all in one.
    Optical out Audio Audio format to surround sound. Better sound quakl
    Hope this helps
    Jul 20, 2011 | Televison & Video
    I get the video, but no audio. I have tried several options and if I do get sounds it's just the loud noisy distortion like sound...
    go to control panel click sounds, speech audio devices, then sounds and audio devices.click audio. choose if you are using usb jack or the realtek hd audio output....
    Dec 03, 2009 | KWorld Xpert DVD Maker USB 2.0...
    I DO NOT HAVE ANY IDEA WHAT IS THE USE OF THIS PRODUCT AND HOW TO CONNECT IT.PLEASE,IF YOU CAN HELP ME AND GIVE ME A DESSCRIPTION OF HOW TO USE IT AND CONNECT IT,I'LL APPRECIATE THIS.. THANK YOU
    this unit will play your television sound through a set of 5 different speakers enabling you to have 5 seperate sounds from 5 seperate speakers simultaneously, giving you the sensation that you are in the middle of what you are watching. you will need a set of 5 surround sound speakers and a sub woofer (speaker that plays low frequency sounds so the speakers dont have to) the video and audio come into the phillips receiver and then the video will be sent to the television and the sound to the speakers.
    Usually send the video signal from your cable box to the video 1 (video in) port on the phillips receiver audio signal from the cable box to the audio in on the receiver under video 1 --video cable will go in a yellow port. audio will be a fiber optic audio cable you can buy at any electronics store and go into the audio in port for Video 1. then connect a cable to the video out port for Video 1 and into the back of your television on any of the video in ports.
    Nov 29, 2009 | Philips FR965DHT Receiver
    My Onkyo Tx-Sr700 sound is not working. I have speakers connected for surr. sound but I can't figure out what buttons to press to turn them on for tv. Tv is video 1
    make sure you have audio cables connected from your cable providers audio out to your receivers audio in on video 1 press the video 1 button you should hear the sound.
    Oct 16, 2009 | Onkyo TX-SR700 Receiver
    Audio Issue
    component has 3 video cables.... then you have to use the composite Red & White cables as your audio.
    so you are using both the component video with the composite audio to achieve this. 5 RCA cables total. you will NOT be using the composite video cable(yellow). But you will use the Red & White for audio...
    simple.. good luck
    Sep 25, 2009 | Microsoft Xbox 360 Console
    Sound problem
    hi
    scan your system with avast,quick heal and symantec with latest update.
    then uninstall sound driver and install again.
    Apr 11, 2008 | Computers & Internet
    No sound
    You must connect from audio out to audio in and. Video out to video in
    Jan 07, 2018 | Concept Slot Load Half-Din DVD Player Car...
    Jwin JD-VD130 DVD Player Logo
    120 people viewed this question
    Top Jwin Televison & Video Experts
    Ekse
    Jaime Hernandez
    Sheldon Dedek
    Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
