Question about Maytag Neptune MAH5500B Front Load Washer
Neptune washer won't unlock, start cycle. now when i attempt to turn on it has a motor sound with no action
  • kmtar May 16, 2010
    nd on display. motor now making grinding sound
    what does nd mean and now that the motor is making a pulsating grinding sound when i attempt to engage a cycle
  • 11,896 Answers
Could be a faulty door switch itself. If the switch is bad, washer will remained lock and the washer won't run. Try unplugging it for an hour, press and hold start button for 5 seconds, release, wait 10 minutes, and plug back in. See if this resets and unlocks your door.
Here is a service manual if you need it:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Posted on May 16, 2010
  • 1 more comment
    what about the motor pulsating off and on, almost like it is cycling. will unplugging "cure" this?
  • Nate Stansfield
    Nate Stansfield May 16, 2010
    OH! You have the no drain error. Either the pump is not functioning or the drain is clogged!
  • Nate Stansfield
    I am guessing that your pump is starting to fail, but see if you can
    check it out.
    Here is a service manual that will show you how to get into it.
    http://www.servicematters.com/maytag...s...
    from memory I do not think there is a drain filter, I could be wrong. If you see one, try cleaning it out. But it is an electric pump
    and it can wear out, get damaged and it can be clogged especially if
    you use to much detergent.
  • 6,784 Answers
HI. The ND code is in reference to the drain pump. it is jammed or the actual impeller has detached itself for the inner drive-shaft. this is an internal issue, concerning your drainage pump. The unit will not operate properly in this state. The necessary actions are to extract the pump for inspection. There may be some sort of obstruction inside the pump. if it is , indeed, grinding as you have stated, this will confirm that the impeller may be broken. In this event, the pump will need to be replaced.
Replacing the drainage pump will correct this issue.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the wax motor for proper resistance. To check the resistance, disconnect the electrical supply from the washer and remove the wire harness from the wax motor terminals and place ohm meter probes on it. The wax motor should have a resistance of approximately 1900 ohms at room temperature. The machine control monitors the door lock mechanism to ensure the door is locked. This is done through the door lock enable switch. During "lock mode," the shaft of the door lock mechanism is pressed forward by the door lock wax motor, and the shaft presses in the button of the door lock enable switch. If the machine control board sees the switch OPEN during the spin cycle, the machine control board will automatically shut the washer OFF. This is caused by a weak spring in the door lock wax motor. Replace the complete door lock mechanism. To order the door lock and how to replace it instructions please see the link---
Maytag Neptune Washer Door Lock
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith May 16, 2010
    Somehow I missed the error code in your post, from
    what I understand the error code ND means
    “No Drain issue”. You’ll need to
    check for any restriction in pump assembly. It can also be due to a restricted
    drain hose or loose wire at pump. If after cleaning the drain hose the issue is
    not resolved then it means the pump has gone bad and unfortunately needs to be
    replaced. Please do accept the solution if the issue is
    Thanks
    Rylee
My maytag neptune tl stops after wash cycle it will start for a few secounds then stops and will continue this start stop action till i hit the stop button
The washer is trying to go into spin but failing. The two sprag clutches are probably sticking, This usually indicates a water leak.
The seal should be replaced. The bearing and sprag clutches should also be checked and will probably need to be relubricate or replaced.
Apr 15, 2016 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune mah5500b sr code
Machine control is attempting to drive the motor but is not seeing any tach response.
Visual check shows motor is not moving. (Locked, Hall Sensor fault).
Evaluate wire harness for loose or unhooked connections.
Oct 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Neptune MAH5500B waon't spin - clothes very wet at end of cycle. Tried to just spin but no spin action and timer just goes down to 1 minute and stays there.
turn back to spin,
and see if you get a lock light,
if your lock is working you will need a new motor control,, and maybe a new motor
Oct 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer (top of the line)
some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Oct 26, 2006 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
