D-Link DI 514 Wireless Router (DI-514) Logo
Posted on May 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not connect to 192.168.0.1 I have D-link
I have D-link modem
i want to set a password for my wireless network at home...
Anonymous
Level 2:
New Friend:
  • Expert 86 Answers
  • Posted on May 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
86
Questions
0
Helped
18831
Points
237
If your network is open and passwords are default, very probably someone changed the password along with the IP address of the router (formerly 192.168.0.1) try 192.168.2.1 or something along, if you try more than 5 addresses its better to reset the router (warning: sometimes ISP set configuration values that are lost if the router is reseted call your ISP before doing this).
To reset:
  1. Find the 'reset' button in your modem.
  2. Unbend a paper clip until it is straight.
  3. Turn the modem on.
  4. Use the paper clip to press the button until the lights start flashing.
  5. Wait a moment while the router reboots.
  6. Your factory settings are restored.
2answers
When i had to change modem my roku will not work.
If your attempting to connect your Roku Streaming Player to a new modem/router, which has wireless capabilities, and you know the network password... You can simply connect your Roku device through the on-screen menu of your device. Just scroll down to the settings choice of the onscreen menu of your Roku device on your Television. The first choice under "Settings" should be "Network," and the next two choices when you click on Network will be "Wireless," and " Wired."
If you're connecting using an either-net cable, make sure the Ethernet cable is connected to both to Your Roku device, and modem/router, then Choose "Wired," and Roku should connect to the Modem/Router.
If you choose to connect to the network wirelessly, choose "Wireless."
Wireless will give you the current status of any connection, and at this point you can choose "Set up new WiFi connection." There you will find an option to scan for all available, or visible, wireless networks. After scanning you will get a list of visible WiFi networks, and if they're "Open" or "Secured." Your network will most likely be the strongest signal, and first in the list. When you choose your network, you will be asked to enter the network password... When done, hit connect/enter...
If your network is secured, and you don't know the password, let me know which model modem you have, and I should be able to walk you through obtaining, or resetting the password.
Configuring dlink 1320
Wirelessly or cable ?
D-Link Router to an AT&T DSL Modem
With an always-on, high-speed Internet connection like DSL (Digital Subscriber Line), a router is a prudent addition to your local network.
It filters out unauthorized access to your network, which prevents an intruder from accessing computers that are connected to that network.
However, getting your computers, routers and modems on the same page may not work right "out of the box."
There are a few things you must be aware of, especially if this is a wireless network.
Unplug your DSL modem and D-Link router.
In order for the network to properly recognize its devices, these devices must be attached in a specific order.
Plug in your DSL modem's power cord.
There is usually no power button on a modem.
Simply plugging in its electrical cable will turn it on.
Give your DSL modem a couple minutes to re-establish its connection to AT&T's network before taking any further action.
Plug in your D-Link router's power cord.
Like the DSL modem, this router will probably not have a power switch; simply plug in the power cable, and it turns on.
Let the D-Link router sit for a couple minutes while it establishes its connection to the DSL modem and AT&T's network.
Physically attach your computer to the router with an Ethernet cable.
Even if the router and modem are wireless, a physical connection must be established to properly configure the router.
If this is not a wireless network, then your setup procedure is essentially complete.
To access a D-Link router on your network, open an Internet browser and navigate to the 192.168.0.1 address.
This will bring you to your D-Link router's interface.
The default User Name is "admin" (without the quotes), and there is no password.
Enter the User Name and click the "Log In" button. This will bring you to the Setup window.
Refer to your D-Link router's documentation for changing the default password (highly recommended) and forwarding ports.
If this is a wireless network, you have a couple further steps.
First, change your network's SSID (Service Set Identifier) title, so that you can recognize it when other wireless networks are nearby.
Also, choose your wireless encryption and passphrase. WPA2 (Wi-Fi Protected Access 2) is a solid option.
Specific instructions depend on your model of D-Link router; so refer to your documentation (which can usually be found at the manufacturer's website if you do not have it on hand).
Disconnect the Ethernet cable from your computer.
Your new wireless network should be visible with your computer's wireless adapter.
Windows and OS X will notify you of networks in range when your adapter is active.
Connect to the one with your SSID, and enter the passphrase.
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Wireless Network D-Link
If you have a D-link wireless network, your computer is susceptible to outside intruders unless you take preventive measures to prevent intrusion.
There are some important settings that you need to change within your D-link control panel to add an extra measure of security.
By changing these settings, the intruders will have no other choice but to choose another computer to attack.
Type the router IP address, "192.168.0.1", into your Internet browser.
Press "Enter" on your keyboard.
Enter your username and password to log into the D-link configuration panel.
By default, the username is "Admin" with a blank password field.
To prevent outsiders from being able to access your D-link router's configuration panel, change the username and password to something more secure.
This can be done by selecting "Tools" from the menu and selecting "Admin."
Select "Administration Settings" and enter your new username and password.
Save your changes by clicking "Apply."
Enter the IP addresses for the computers you want to give access to your router.
You can do this by clicking the "DHCP" link underneath the "Home" tab. Click "Apply" to save the IP addresses.
Select the "Wireless" link underneath the "Home" tab.
Enter a name in the "SSID" field to identify your wireless network.
Choose "WPA" for your "Security" option.
WPA will provide the highest level of security for your wireless network. Create a WPA password to access your wireless network.
For maximum security, enter a combination of numbers, letters, and symbols.
Store your password in a safe place in case you ever forget it.
Click "Apply" to save your settings.
Install a software firewall program on your computer to add an additional measure of security for your wireless network.
A few of the popular firewall programs available are Norton Antivirus, McAfee and Zone Alarm.
How to set up D-Link router
Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem.
Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet.
Remove the power cord from your modem and wait 10 seconds before plugging it back in. This will reinitialize your modem and force it to establish a connection to the D-Link router. Your router will immediately begin distributing a wireless network with the "D-Link" network name.
Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser. Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field. Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network. Click "Apply" to save the changes to the router's settings.
After cable co. split cable and installed another modem, D-Link WBR 2310 router no longer works with its original modem. Tried resetting, unplugging, etc. Can't get wireless.
Use an Ethernet cable to connect your computer to one of the LAN ports.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for a line of output like:
Default Gateway . . . . . . . . . : 123.468.32.1
Start Internet Explorer
Type http://123.468.32.1
Press Enter
Login to your router
Click to run the "Wireless Networking Setup Wizard", to:
1. set an SSID
2. set an encryption-level, e.g., 'WPA' or 'WPA2'
3. set a password for your network
Click OK to restart your computer
Use your wireless device to connect to that SSID, using that password that you set.]
I have a Arris TM722 modem and I need to know my SSID number and password? please help me!
An SSID is the name of your wireless network connection and doesn't have to be a number. As I don't believe that this modem supports wireless connectivity, it should not prompt you for an SSID or a password. If the modem is plugged into a wireless router however, and a wireless network has been set up, the SSID will be related to the wireless router.
Generally most devices can scan for the SSID when attempting to connect to a wireless connection. If there is an "automatic" setting or a "find networks" button, you can try that and choose your wireless connection from the list provided. For a password, you may need to ask whomever helped set up your wireless network.
Trying to connect my mobile to my wirelesss Netgear,keeps asking for wep
You have set your wireless connection as Secured Wireless Network when you configured your wireless Modem/Router, so you need the "Network Keys" (ie the set password) to access to your wireless network. That is why your wireless cxonnection is asking for the "WEP KEYS" in order to connect to your Wireless Acess Point.
You can read your modem/router manual how to access to your router to see what password you have set.
or
Refer to the link, here
Hope it helps.
2helpful
2answers
My D-link G604T connects with WEP but not with WAP
When you change the WPA encryption in the wireless router, you also need to configure the wireless card in the computer with these settings.
Please click in this link to secure your wireless network, configure the wireless router and the wireless card in the computer and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
When trying to connect to my wireless modem it can't get an ip ad
Is it a modem or a router ?
If it is only modem then only 1 computer will go online at a time. If you have any other computer online already then the second computer will not go online and it will not get IP address.
If it is a combination of modem and router OR if it router then you can open the set up page of the device and find out the password.
For this you will need a computer connected to the device.
Check the IP address and open the set up.
Click Here for more info
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
