Question about Toshiba Portege R100 Tablet PC
NO POWER ON
Hallo
sometimes my lapotop don't start, pushing the button power and the icon of cable cord blinkink for many time... what happen to my pc?
  • 21 Answers
Try removing the battery and power cable then holding down the power button for 10 seconds. Reconnect the battery and power cable then press power again to turn on. It's usually a hibernation problem. Some newer toshibas also had a motherboard problem. I'd look up your model on the support section of www.toshiba.com and see if there is an updated motherboard driver install for your make.
Posted on May 30, 2008
How do I turn on my pandigital supernova tablet?
It could be two things, Jack: I would start by plugging it in to your charger for about 24 hrs to make sure it's not just the battery after that length of time not being used...OR, you might have to reset it to factory settings.
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults.
First you need to make sure your tablet is powered off.
Hold down on the Volume + button and hold down the Power button at the same time.
  • As soon as the tablet's screen turns on, let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
  • At this point you will see a screen with boot options.
  • Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
  • On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
  • At this point it will be going through the wiping and resetting process.
  • When it's done you will see the first screen you came to when you first started the setup.
  • Just tap the Power button to select Reboot System Now.
Stuck in Android System Recovery Tips to Fix Recover Lost Data
Apr 27, 2016 | PANDIGITAL SuperNova
Unable turn irulu 10 tablet off. Frozen. icons wont do anything.holding power button in for awhile, tried Crtl, Alt, and delete button at same time & stays on. Please help asap. Thank you Bonnie
Try a hard reset. The 10" Irulu has a reset on the right bottom edge. You'll need to stick a sharp pointy pen that fits in the in the small hole, push. Press the ON button and see if it starts. Resetting will change the time and date to the default setting of your unit.
May 07, 2015 | Tablets & eReaders
Digiland t.ablet does not power on
have you fully charged it?? check the power cord for breaks or where it plugs in sometimes if you pull the cable too hard the cable will rip without you noticing. try an other cable.
Jan 11, 2015 | Tablets & eReaders
How do I fix my Toshiba tablet that won't show me that it is charging?
Have you checked the following:
  1. Power cord for breaks
  2. The power outlet you are connecting into (try at least 2 other outlets before settling, but use different outlets for the sake of argument.
  3. When was the last time you charged and it actually did?
  4. Do you have the correct cord?
  5. Have you tried to replace the cord?
Nov 22, 2014 | Toshiba Tablets & eReaders
How can I get the samsung tab to turn on
I'm assuming this is a new device for you. Do/did you see the battery charging icon in the middle of the screen when you plugged it in? If so, great. If not you are having a problem charging your tablet. Most likely either a bad cord, a cord that's pulled out a bit on either end, or an outlet that's turned off or not working.
If the icon was present and indicates a full charge, then simply press and hold the power button for a few seconds and the screen should start right up.
If it worked for you in the past, check your power cord. I've gone thru 3 on mine.
Aug 14, 2014 | Samsung Galaxy Tab Tablet PC
Nexus 7 won't turn on
Pop the back off, unplug the battery for about 30 seconds, plug the battery back in, put the back cover back on. You will find it will start no problem.
May 19, 2014 | Google Nexus 7
Playbook not starting
I had many problems with my playbook. 1st thing you want to do is hit the power button on top if the playbook is still not on hit the volume up and down at the same time (I do right then left) then push the power button and sometimes it will be on.
Oct 25, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Neverending shut down
Keep your finger pressed on the power button and it will shut down
Feb 25, 2010 | Compaq tc4200 Tablet PC
Toshiba Portege R100 Tablet PC Logo
222 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
