Question about Syntax LT30HV 30 in. HD-Ready LCD Television
How do I unlock the child lock on Syntax LT27 HV/LT30 HV when the remote control does not work??
  • 20 Answers
Use the buttons at the bottom of the screen right below the bezel with the ON/OFF blue light. The buttons are hidden as they face towards the floor. But you can access the OSD by using MENU and you can navigate using the CH +/- or VOL +/- unfortunately I can't check because my TV is being repaired (got the same model)
Anyway if it helps here is the order of the button left to right while looking at the screen:
[INPUT] [VOL-] [VOL+] [CH+] [CH-] [MENU] [POWER]
I hope this helps you :)
Posted on Jul 23, 2010
How to unlock HV-DX2 DVD -VHS
What kind of lock are You speaking of? The child lock? look on the remote it should say child lock, push it! If You are talking code try 4 zeros!
Jul 13, 2017 | Televison & Video
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
How will i have this resolved? my sanyo k50 tv showing "locked" whenever turned on??
The TV is locked by someway. If you're using a universal remote control, this might have happen. If you wish to unlock it, you must have its original remote control. For more information go to http://electronicshelponline.blogspot.com/ Unlock procedure to many brand TVs are given. Pull up older posts.
Nov 28, 2013 | Sanyo Televison & Video
Awa lcd ltw32ds
You need the original remote control to unlock the TV.
Jan 01, 2018 | Televison & Video
I want to unlock the child-lock key without using a remote control as my remote control is not working, and now my television is stuck on AV. mode. I cannot move anywhere... Please help!!!
Different brands use different methods---many RCA sets it can be done manually by holding the vol up and channel up together for over 10 seconds.
Other brands require the original remote and a 3 or 4 digit number code.
Dec 07, 2012 | Televison & Video
I want to unlock the child lock key on my LCD TV
Since this set like all others with the "child lock" require a code to be entered and the remote is what is used, I would say it cannot be done without the correct remote and the password.
Dec 05, 2012 | Televison & Video
MY TV IS LOCKED WITH A CHILD LOCK AND I LOST THE REMOTE TO UNLOCK THE TV PLEASE HELP.
Goto the near service center and a new remote of your tv brand and unlock your tv by child lock. its the simplest solution for your problem
Jan 06, 2011 | Televison & Video
My syntax Olevia LT30 HV turned on and displayed blue screen for 1-3 sec and than no signal nosound??any advice seems to be inverter issue.
Since you lost both sound and picture, I would suggest to take a look at the power supply for bad filter capacitors, look for bulging on the top of capacitors. If the backlight inverter board is bad you should still get the sound.
Apr 23, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
Child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
May 31, 2008 | Philips Magnavox Learning Universal Remote
Syntax LT30HV 30 in. HD-Ready LCD Television Logo
528 people viewed this question
Top Syntax Televison & Video Experts
Jaime Hernandez
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
