Question about Kodak EasyShare DX6490 Digital Camera
Charged the battery,and the cammera still wont turn on
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, Quite possibly the battery is a few years old and has lost the capacity to power the unit on,these type batteries become weak over time and the unit requires quite a bit of power to boot the camera,only solution is try a new battery that has been charged for at least 4 hours.Hope this solves your problem,the battery is very cheap on E-Bay,Battery is KLIC-5001.
Best Regards,Russell
Posted on Jan 23, 2013
What happens if the charger is in but it does not charge the battery
Send the charger back and get a new one, preferably an official one and not a universal one
Nov 21, 2014 | Kodak EasyShare Z612 Digital Camera
Too much power and now lorex camera wont turn on
CAMMERA DESTROYED !! MOTION LIGHTS USE 120 VOLT AC POWER
CAMERAS USE 12 VOLT DC POWER
WRONG TYPE AND AMOUNT OF POWER !!!
Jan 16, 2014 | Lorex Home Security
My samsung st66 camera was dropped and it say the zoom did not operate normally zoom wont operate normally
When I turn on the camera it says "The zoom did not operate normally, insert the battery again and turn the camera on..."
i reset my cammera but problem still please guide me
Nov 10, 2012 | Samsung Pl20 - 14.2 Megapixel, 5x Optical...
My cammera will not charge! The orange light does not show up when charging ???
There are 3 possibilities to charge the battery of the camera:
1. Connecting the Olympus' USB cable to camera and computer.
2. Connecting the wall charger to the camera with Olympus' USB cable.
3. Using a specific separate wall charger for LI-50B batteries.
Be sure to connect the cable well and if the orange LED does not light when trying to charge the battery using above points 1 and 2, there might want to exchange the Olympus' USB cable first to check what's wrong. (Cable model: CB-USB6). Another point is to check if the battery is seated well in the camera.
Jun 05, 2011 | Olympus SP800UZ Digital Camera
My 3 months old camera is showing battery exhausted. How can problem be resolved. We seek your advice on the matter.
this is mostly due to defective battery nikons quality services are good but u sometimes end up with a bad model
u can take the cammera to your dealer as it is under warranty so they should replace it
if you use the cammera with flash all the time then too it decreses battery standby
if all else fails try getting a new battery from e bay on the cheap
Mar 14, 2011 | Nikon Coolpix 3200 Digital Camera
Not turnning on
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Aug 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Do not know how to get the battery charged in my vivitar DVR 545 didital cammera
Try Ebay, they have chargers listed for you camera.
Jul 02, 2009 | Cameras
Casio digital cammera
are you sure the battery is charged?
put the battery on the charger.
is it blinking red or does it stay red?
if it's blinking red, it won't charge correctly unless you do this:
MATERIALS: 9 volt battery, 2 pieces of wire the same length, casio battery
DIRECTIONS: connect the + sides of each battery with a wire, and the - sides of each battery with another wire. [I just held them there, but maybe you can tape them if you're having trouble.] Hold it for 30 seconds. Then try charging it. If it doesn't work keep trying it until it does. TRUST ME! It took me 5 times to do it effectively.
Sep 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Yep. another lens stuck.
it depends on what the problem acctually is. In my experience with cammeras such as these, a problem of this nature is not worth the trouble, but if you really like the cammera then take the covers off by removing the screws around the cammera body. Start by removing the back peace. you wont need to remove the door for the batteries or the two screws around the mount on the bottom of the cammera that hold the screw tripod mount in place. once you remove the backing you will expose at least one more screw on the side that holds the front cover on. you will want to very carefully remove the wires for the backing by pulling back the ribbon cable retainer clip and the ribon cable retainer clip must be pulled back carefully for the shutter switch as well when removing the front pannel of the cammera. Unplug the yellow wire for the micro switch in the front if applicable and then you will have exposed the lense. remove the screws holding the lense assembly in and then look around at the operation. THERE IS A CAPACITOR IN THE FRONT OF THE CAMMERA THAT WILL SHOCK YOU!!! DO NOT TOUCH THE BOARD. I've been shocked by the thing at least 3 times today so dont get all hasty. you will probably notice one of the gears are stuck or something you can buy a new lense assembly and install it but it is probably just as much as the cammera. I would sugges trying to repair it or if it is too damaged throw it away. It depends on what you find. you can look up small gears on line but it also may just need to be set back in or cleaned. You may also want to replace the cammera battery while you are in there. When removing the back pannel start from the bottom of the cammera and slightly hinge up and pull the backing away genly as to not snap the retainers in the upper part of the cammera or yank out the ribbon cable. REMOVE THE BATTERY BEFORE YOU BEGING. WITH THE BATTER REMOVED THE CAPACITOR WILL STILL SHOCK YOU. be careful.
Aug 16, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Fuji finepix A120
are you using rechargable batterys or weak batterys. my fuji won't work unless I use a e^2 titanium batterys. they have lots of jam (3500's?). anyways when the picture or ccd goes to charge there isn't enough juice to fire and the cammera dies. or maybe there is junk on the connections and won't let enough volts through. rechargeables are bad becouse they don't have the volt output needed - 1.2v charged I beleive. the other batterys are expensive but they've been in my cammera for three months, or about 300 pictures.
hope that helps :)
Feb 01, 2008 | Fuji FinePix A120 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
