Question about Kenmore Washing Machines
My older kenmore all in one washer leaks. Any ideas where I can get a repair manual?
  • oldguy5 May 16, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. First, see the Sears parts site for your washer:http://www.searspartsdirect.com/partsdir... Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
  • 714 Answers
Repairclinic.com
Posted on May 16, 2010
My washer continues to leak hot water in the tub when its not running and the temp is set on cold any ideas ?
Water is leaking past the hot water fill valve solenoid .The only repair is to replace the fill valve assy. (hot and cold) this is not a hard repair to do......
Sep 07, 2010 | Kenmore Washing Machines
Kenmore washer 25842 leaks
Repairclinic.com has a repair manual available for Kenmore direct-drive washers for about $20. The item number is 1170635.
The back panel is not designed to come off on this model washer. The operator console comes off, but the panel along the back of the washer does not. You need to remove the exterior washer case to access the internal components.
If you have a leak, the most common cause is a worn drain pump, or leaking drain hoses, but you need to disassemble the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect your washer for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
Read through the instructions provided and let me know if you need further assistance. I hope this help you.
Jan 10, 2010 | Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
KENMORE FRONTLOAD WASHER Model# 41741052000
very common for the tub seal to leak - or bellow to be ripped.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Kenmore 44102 Front Load Washer
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
